coaster wrote:I stand to be corrected but I thought the rings needed to be 'eased' back into the piston as the piston rises past the exhaust port. That means that the widest part should be at the bottom surelyI had a 225 barrel ported a few years ago and even with the correct shape, the 1.5mm cast rings snagged in the exhaust port and broke the piston within 700 miles
so be careful.
Great work so far by the way and I agree, doing it yourself and the feeling the results of your calculations and fettling is very rewarding. I did my own homebrew reed conversion to one of those ST225 ally/steel barrels, hacking away with my dremel, grinding out a finger port, widening the transfers like yours, very, very rewarding![]()
Good luck
20180919_184901 by richardhenderson1968, on Flickr
20180919_183202 by richardhenderson1968, on Flickr
20180922_181540 by richardhenderson1968, on Flickrdickie wrote: I've created a lot of mess while cleaning it up; some of this probably got into the holes and is stopping the studs from seating fully home. I've tapped the holes as much as I can with a no2 tap, but I'll try to pick up a blind hole m8 today.
20180926_191702 by richardhenderson1968, on Flickr
20180927_184055 by richardhenderson1968, on Flickr
20180927_194725 by richardhenderson1968, on Flickr
20180927_194737 by richardhenderson1968, on Flickr
20180927_195445 by richardhenderson1968, on Flickrdscscotty wrote:Concentrate more on port timings than squish, the timings will have more of an affect on performance and the characteristics of the motor than the squish, you can look at that at a later date if necessary.
I've just ordered some MB ones as they're waisted and around 11mm longer than the ones I have. I had considered adding helicoils, but dismissed it as unnecessary. Maybe I should reconsider?Warkton Tornado No.1 wrote:The PX studs are inexpensive & an excellent rolled, marginally oversize thread & the longer threaded end can often be used to further increase the strength of their fit within the crankcase by increasing the depth of the M8 holes if you have no access to Helicoils. I torque the head to 22.5 ft/lbs & don't want to be worrying about the studs pulling out.
Ok, I don't think I'll need to with the longer studs, but just in case, how deep can I go? typically of course.Warkton Tornado No.1 wrote:Stud length can easily be compensated for simply by counter-boring the cylinder head holes deeper. Hard, stainless, very thick M8 washers are available via eBay that can take advantage of a modified counterbore size. 19 mm diameter if memory serves.....
I'm trying to optimise here, so I;m going for a corrected ratio of about 6 or 6.2:!Warkton Tornado No.1 wrote:Compression ratio, & therefore volume needs to be safe, but ballpark figures are good enough & will hardly be affected by squish variation.
Yes, I'll be aiming for a similar figure.Warkton Tornado No.1 wrote:The squish is very important as the piston sheds it's heat by getting to within the closest distance practicable. I always aim for 1.0 mm & whilst that may seem a faff, it is worth it for the optimum results. But then again, I always centralise the head & barrel with either hollow dowels or pin dowels.
I need to get the head and possibly the barrel skimmed to achieve a decent squish, so I've no need for head gaskets.Warkton Tornado No.1 wrote:Head gaskets are prone to fail. Personally, I refuse to use them in any engine build as there is always a way in which you can achieve the desired geometry without having to employ them.
dickie wrote:Warkton Tornado No.1 wrote:The PX studs are inexpensive & an excellent rolled, marginally oversize thread & the longer threaded end can often be used to further increase the strength of their fit within the crankcase by increasing the depth of the M8 holes if you have no access to Helicoils. I torque the head to 22.5 ft/lbs & don't want to be worrying about the studs pulling out.
dickie wrote:Warkton Tornado No.1 wrote:Stud length can easily be compensated for simply by counter-boring the cylinder head holes deeper. Hard, stainless, very thick M8 washers are available via eBay that can take advantage of a modified counterbore size. 19 mm diameter if memory serves.....
dickie wrote:Warkton Tornado No.1 wrote:Compression ratio, & therefore volume needs to be safe, but ballpark figures are good enough & will hardly be affected by squish variation.
dickie wrote:Warkton Tornado No.1 wrote:The squish is very important as the piston sheds it's heat by getting to within the closest distance practicable. I always aim for 1.0 mm & whilst that may seem a faff, it is worth it for the optimum results. But then again, I always centralise the head & barrel with either hollow dowels or pin dowels.
dickie wrote:Warkton Tornado No.1 wrote:Head gaskets are prone to fail. Personally, I refuse to use them in any engine build as there is always a way in which you can achieve the desired geometry without having to employ them.
Users browsing this forum: No registered users and 76 guests
