electrickery question
Postby ROClarke » Mon Sep 10, 2018 1:43 pm
I have a AC/DC intellio convertor purchased from Anthony Tambs, can I use it to charge some sort of battery, say a12v 3.4ah re-chargeable acid battery or similar to the ones MB is selling or would I need to fit something to stop it overcharging the battery ?
Whilst I am obviously after help and comments, please keep them to ladybird book level ! :D
ROClarke
Re: electrickery question
Postby HxPaul » Mon Sep 10, 2018 1:56 pm
I think the best person to address that question to is Anthony Tambs.
Postby Paul_from_Thornbury » Mon Sep 10, 2018 2:55 pm
I wouldn't think so, that device is to provide a stable DC supply for gadgets.
If you want to charge a battery then use one of these, supplies AC to your harness as normal and a DC supply to charge the positive side of the battery, the negative battery terminal goes to earth.
https://www.lambrettaspares.com/spares/ ... m0079.html
I assume your scooter is AC, what are you trying to achieve with a battery?
Last edited by Paul_from_Thornbury on Mon Sep 10, 2018 3:21 pm, edited 1 time in total.
Paul_from_Thornbury
Postby ROClarke » Mon Sep 10, 2018 3:14 pm
Paul_from_Thornbury wrote:I wouldn't think so, that device is to provide a stable DC supply for gadgets.
If you want to charge a battery then us one of these:
I want to have a stable power supply, ideally when the scooter is at rest as well, the convertor is fin but my lights go dim when my Sat Nav is first switched on and then stabilise,I think it is using a lot of the available power.
ROClarke
Postby ROClarke » Mon Sep 10, 2018 3:24 pm
So I may be better off ditching the convertor and going back to using a rectifier of the type suggested ?
ROClarke
Postby Paul_from_Thornbury » Mon Sep 10, 2018 3:28 pm
The Intelliconverter is only really good for the SatNav.
If you want the lights not to go dim, then ideally I would be looking at doing a full DC conversion. If your scooter is AC you can't just connect a DC battery into the same wiring for the lights that are supplied with AC.
So you need a stator that's had a DC conversion done (earth removed and brought out of stator on an extra yellow wire) then you a Wassell/Podtronics rectifier to give you DC to your charge your battery, then the wiring harness connecting to the battery.
Paul_from_Thornbury
Postby ROClarke » Mon Sep 10, 2018 3:56 pm
Paul_from_Thornbury wrote:The Intelliconverter is only really good for the SatNav.
Thanks Paul
I do not reall want tostart messing about with the stator, which is Varitronic.
ROClarke
Postby Scooterlam » Mon Sep 10, 2018 4:56 pm
I run a tambs dc output regulator to charge battery, easy as...
check with him or Broady 1st encase there's a difference with varitronic.
better safe than sorry.
Scooterlam
Postby ROClarke » Mon Sep 10, 2018 8:42 pm
Scooterlam wrote:I run a tambs dc output regulator to charge battery, easy as...
When you say regulator do you mean one of his converter ?
ROClarke
Postby Scooterlam » Wed Sep 12, 2018 6:48 pm
No 12v regulator with dc output.
I think ant says you can't run stuff direct and need a battery or a capacitor.
Scooterlam
Postby ROClarke » Fri Sep 14, 2018 8:29 pm
Scooterlam wrote:No 12v regulator with dc output.
Cheers,just got a BGM regulator and a battery.Will have a play tomorrow.
ROClarke
