Fat Trucker wrote:I had a similar issue years ago, the flywheel boss looks like it's a replacement one i.e. If you have a Li flywheel you can replace the center boss for a gp one(Scooterrestorations sell them) I replaced the Li boss for a gp one and used Allen cap bolts and lock nuts provided, drilled old rivets out to the size of the bolts popped them through, nuts on with super loctite. Jobs a good one, lapped with grinding paste, cleaned and pop flywheel on to strobe up flywheel off and on no problem. Had flywheel on for a short while then had to remove flywheel and had nearly identical marks as you've got mmmmmm. After 2 fucked cranks and flywheel bosses I was informed you need to tap the holes for the bolts if not the pressure of the spinning will move the boss very slightly causing friction hence it looks like weld.
Of course I may be wrong as I normally am according to the wife.
Just have a look in the hole the bolt has come fro to see if it's been tapped,
Cheers ove
HxPaul wrote:How come the original rivets hold it in place...........the flywheel isn't tapped for them.
