Jetting advice.
Jetting advice.
Postby SILGP » Thu Aug 30, 2018 8:31 pm
Hi , I've bought a series 2 fitted with a smallblock 200cc kit from buzz solomoto.
I'm gonna change the carb to a 26mm phbh dellorto. It will run without a filter and with a clubman type exhaust.
Could anybody give me a starting point for the jets please ?
Cheers.
SILGP
Re: Jetting advice.
Postby ULC Soulagent » Fri Aug 31, 2018 1:01 pm
Check out link below, will give u a baseline setting
http://www.lambretta.co.uk/downloads/carbjetting.html
ULC Soulagent
Re: Jetting advice.
Postby SILGP » Fri Aug 31, 2018 6:32 pm
Thanks for the reply. I'll use the mugello set-up as a starting point although my top end can only be described as a budget kit !
SILGP
Return to Carburettors
