Scooterdude wrote:If you still have the RT 230 why not convert it to reed valve? Should increase power a bit and increase fuel economy as well. Yes i to have been following the reed valve GT thread on Facebook, doesn’t sound great but Darrell Taylor seems to have the answer to the problem and is offering an alternative set of petals to fix things.
At the risk of sounding like a long playing record; look at the RT 195 and again the idea of converting it to reed, should tick all the boxes.
For what it’s worth im getting around 90 miles to 7 litres of fuel on my RT 235 full MB touring tune reed on a long run.
ULC Soulagent wrote:My reedvalve rt 200, 25 delly, bgm clubman does 104 miles b4 I go on 2lt reserve using a 11 lt tank
Well happy with that.
Oh it’s a Broady touring tune on it as well.
Currently building a rt230 version of it
Storkfoot wrote:I have done several thousands of miles on a GT186 including Adria and Davos Euros. I have never doubled up on the reeds and never had one break. I do replace them quite regularly though and I don’t run an expansion pipe. I have an MB/bgm Clubman and a PHBH 30. When I have checked the mileage, I reckon I get 12 to 14 miles per litre with rally gear.
I’d say it ticks all the boxes but I have encountered one downside with the MB Clubman, the ubend of which does hang quite low. If you curb your ubend, the sacrificial part may end up being your exhaust flange on the cylinder as this is shaped in a manner to maximise cooling around the exhaust port.
Solid Air wrote:I have the small-block GT Bilko and use it all year round, including for the Euro/C2C etc. In about 10k miles I haven't had any reed issues and they are doubled up.
I would advise checking that the casting allows the reeds to open fully though (I needed a manifold packer) and whether the manifold touches the frame (might need to use eccentric cones and/or fettle the manifold).
As for fuel, before Spain I would get 11-11.5 miles to a litre which works out to 49-51mpg for everyday use, a mix of A roads; town and motorway, and sitting at a steady 60mph would give me 46-48mpg. On motorways there's is pretty much always enough speed spare to pass the HGVs easily.
Set-up is 60/110 crank, 28mm Keihin PWK, BGM V4 clubby and an AF close ratio 4 speed box using 49/20 sprockets (4.9 FDR). This gearbox/sprocket set-up gives a touch more top speed, which I like, but does make pulling away up steep hills harder
During/since my Spain trip, fuel consumption has noticibly decreased though and ironically, I'm wondering if the reeds would affect this and so are ready to be replaced, but haven't had the time to investigate yet.
Would I recommend this kit for someone wanting to build up a small block engine for everyday/touring use and not costing the earth? Oh yeah![]()
Lozmondo, if you've already got the RT definitely consider the M210 for the contrast. I've got one which I'm in the early stages of building and really looking forward to completing it
Solid Air wrote:As I understand it, doubling up the reeds is not related to the barrel casting but because they were originally used in karting and the higher degree of flexibility required due to the higher engine rpm & characteristics which doesn't allow them to work too their optimum on a lambretta.
Happy to be corrected though.
Mark
Users browsing this forum: No registered users and 51 guests
