Wobbly brake pedal
Wobbly brake pedal
Postby dickie » Sat Aug 18, 2018 3:57 pm
My rear brake pedal wobbles side to side. It has a new burass bush, so the pin must be worn. I should have replaced it before paint/build.
Is there an easy fix?
Re: Wobbly brake pedal
Postby bazza3004 » Sat Aug 18, 2018 6:21 pm
would drilling and tapping the pedal post help. ive done this before then used a suitable sized bolt and flat washer screwed in to hold pedal in place but this was on a scoot where circlip groove was worn. it may help your side to side movement if the washer used is up against the pedal until you replace the post.
bazza3004
Postby AlG » Sat Aug 18, 2018 6:29 pm
Aren’t they supposed to have a thick and then a thin washer/shim as well? Not sure which way round they go before or after the pedal and then circlip?
AlG
Postby dickie » Sat Aug 18, 2018 7:38 pm
bazza3004 wrote:would drilling and tapping the pedal post help. ive done this before then used a suitable sized bolt and flat washer screwed in to hold pedal in place but this was on a scoot where circlip groove was worn. it may help your side to side movement if the washer used is up against the pedal until you replace the post.
Nah, the groove is fine. I know what yoi mean about the washer restricting movement but it wouldn't be enough. Starnge thing is that the pedal was a tight fit with the new bush.
Postby dickie » Sat Aug 18, 2018 7:40 pm
AlG wrote:Aren’t they supposed to have a thick and then a thin washer/shim as well? Not sure which way round they go before or after the pedal and then circlip?
Yes, I can't remember the order but I used an exploded diagram when fitting so I'm (fairly) confident that they're correct.
I'm sure I saw a kit somwhere recently that allowed you to remove the post with a grinder or whatever then drill and tap the remainder to accept a screw on post.
Postby dickie » Sat Aug 18, 2018 7:46 pm
Google is your friend.....
https://scooterlab.uk/lambretta-brake-pedal-pin-repair-workshop/
Job for the winter.
Postby shane BBoys » Sun Aug 19, 2018 9:30 am
dickie wrote:Google is your friend.....
Job for the winter.
Good kit for a project un-painted.
Lots of coolant needed for a painted bike but V messy.
Shane
shane BBoys
Postby EddieStone » Mon Aug 20, 2018 9:35 am
I did it on mine and it wasn't messy. You do have to take all the legshields off which is pain but I don't see what could cause any problems. Hacksaw the old pin off and file it flat, centre tap it the drill progressively bigger holes until you get to the tap size, then tap it and bolt the new brake shoe pin in.
It's not hard but you do need to be careful and not rush it.
EddieStone
Postby grandpa » Mon Aug 20, 2018 10:32 am
EddieStone wrote:I did it on mine and it wasn't messy.
Hi Dicky
+ 1 Just dont rush it as Eddie mentions, and keep drill horizontal
Have a look at this:
https://scooterlab.uk/lambretta-brake-p ... -workshop/
Good luck
Grandpa
grandpa
Postby Warkton Tornado No.1 » Mon Aug 20, 2018 4:39 pm
The solution that I have carried out a number of times is to drill & tap the pin to suit a GPW (Gear Pin Washer) after having first removed the end portion @ the circlip groove. The hole size is usually M5 & I would recommend a good, high tensile, socket couuntersunk screw.
The finished end needs to be perpendicular but can be 'short' as the GPW can be shimmed to suit with, say, M5 washers to make the fit to the brake pedal a good running clearance. It's also worthwhile cleaning up both sides of the brake pedal itself (if you can file 'square') to have good surface areas.
Whenever I have done the job, I've also always used Oilite bushes as replacements as they tend to be a little undersized in their bore once pressed in, which helps the whole scenario. If reaming out, be careful not to 'smear' the sintered bore!
I've never had to consider cutting off the pin, but if I were to do so, would look @ socket shoulder screws (stripper bolts) rather than brake pivots. I have used them in my own DIY rear set brakes & they have a ground surface & their thread is still smaller than the main diameter so not too difficult to drill & tap in situ. Although their surfaces are hard, I cut off the heads & drilled & tapped as above for use with a GPW as the pedal can then be shimmed accurately as it is the side load on it that causes rapid wear & the action to feel sloppy.
I hope this alternate take helps....
Users browsing this forum: No registered users and 84 guests
