None Runner
Re: None Runner
Postby CHRIS in MARGATE » Mon Sep 15, 2014 7:22 am
While you're there, change the mag side oil seal. And the drive side.
Re: None Runner
Postby Bilko » Mon Sep 15, 2014 1:55 pm
Yes definately Chris.
Bilko
Re: None Runner
Postby Bilko » Sun Sep 21, 2014 4:41 pm
Cranks, bearings and seals changed.......
Still the same
Bilko
Re: None Runner
Postby Scooterlam » Mon Sep 22, 2014 7:59 pm
Back to the holy trinity, compression, fuel and spark.
Don't assume anything,
Just because you have a spark when you hold the plug against the engine mount, doesn't mean you have one when the plug is fitted and the cap and lead are close to the metal cowl.
Scooterlam
Re: None Runner
Postby MickYork » Mon Sep 22, 2014 8:27 pm
Put the number plate on a running scooter......problem solved :shock:
Re: None Runner
Postby Bilko » Mon Sep 22, 2014 10:12 pm
I wasn't expecting miracles on Sunday when I finished the rebuild and the service was worth doing and when it fired up third kick, for a split second I thought it was sorted....
I know many here are many rolling there eyes at this with my amateur mechanics and more than likely would have the Lambretta running in no time, but I really don't know what else I can try.
Frustrated,
Belfast
Bilko
Re: None Runner
Postby bolzenanker » Mon Sep 22, 2014 10:17 pm
Bilko
Keep at it, I'm rooting for you as I'm sure everyone else must be.
Just think about when it's finally sorted, which it will be, how chuffed you'll be.
Good luck and keep us posted.
:D
bolzenanker
Re: None Runner
Postby MK Monty » Mon Sep 22, 2014 10:41 pm
I have just been back and reread the posts, Im back to stators and flywheels. I know they have all been changed. BUT. when I was messing with stators and CDI I found the height of the pickups varied by as much as 4 mm. I measured the position that the flywheel sat on the crank by putting a wad of blue tack at the pickup position. Using that I figured out that the pick up on my brand new BGM stator needed to be raised by 3mm to get it nearer the centre of the tongues on the pickup magnates.if that makes sense. If your crank has any end float it may move further out of alignment as the revs increase. In my case my timing was wandering 10-15 degrees even after I had removed the M tech and gone to fixed timing. I had used 3 separate CDIs and they all did different things
MK Monty
Re: None Runner
Postby grandpa » Tue Sep 23, 2014 11:47 am
Hi Bilko,
I also have an unsolved problem (gp150 misfiring) where I have changed everything.How are you checking for air leaks to test integrity of crankase seals? a cheap way is to use a cycle innertube and just pump it up to only about 5psi then spray all joints with soapy water. Left it overnight and took pic .Is your compression around 100psi.Just bought compression tester with flexible rubber pipe from screw fix for under £20 100 psi kicking it over and 110 pushing scoot in second gear
Good luck and let us all know how you fix it .Don't give up.
Grandpa
grandpa
Re: None Runner
Postby Scooterlam » Tue Sep 23, 2014 6:47 pm
Can't some one local pop over nd give the guy a second opinion.
He isn't failing for want of trying.
Scooterlam
Re: None Runner
Postby Mark ULC » Tue Sep 23, 2014 10:32 pm
I love to help you Bilko but you have more knowledge than me. Can you get it to Ballycastle and let the knowledgeable folk play with it that weekend :?: If you need a lift up we could organise that.
Mark ULC
Re: None Runner
Postby Toddy » Tue Sep 23, 2014 11:04 pm
Mark ULC wrote:I love to help you Bilko but you have more knowledge than me. Can you get it to Ballycastle and let the knowledgeable folk play with it that weekend :?: If you need a lift up we could organise that.
Good thinking we can all offer an opinion then , surely one of us must be right :shock: :lol: :lol:
Re: None Runner
Postby Marty ULC » Wed Sep 24, 2014 6:30 am
You've tried everything I can think of and more.
Maybe time to start at the beginning again.
Swap plugs, cdi etc out of a working scoot maybe.
Buy some petrol out of a different garage.
Marty ULC
Re: None Runner
Postby Bilko » Wed Sep 24, 2014 9:29 am
My partner just gave me an in depth analysis.
She says “I think it's electrics because it won't stay on".
I'm convinced she's right.
Bilko
Re: None Runner
Postby Mark ULC » Wed Sep 24, 2014 11:33 am
Bilko wrote:My partner just gave me an in depth analysis.
Well once she has done the dishes get her out to fix it!
Mark ULC
Re: None Runner
Postby IaninDorset » Wed Sep 24, 2014 1:39 pm
So mechanically its all AOK and then some?
You're getting a fine spray of the old 2 stroke and fuel?
What about the old Ford common failure, the dreaded earth strap, does the CDI take its earth from the frame which a poor earth strap would cause some issues with? Also remember a poor connection will build up resistances and play merry hell with all sorts of things including capacitance for your hall sensor.
A limp coil could also give you the run around, they seem to work but under load give poor and intermittent sparks but by the time you've taken the plug out, its cooled down enough to give you a kick spark and so you think it is working when it ain't.
The spark plug should go to ground because its all part of the same metal single circuit of the engine casing, have you got one of them neon spark caps as I keep one of them spare for just that sort of thing.
IaninDorset
Re: None Runner
Postby sunrisemac » Wed Sep 24, 2014 9:09 pm
Have you checked all the wires that were disturbed when fitting engine in case there is a broken one inside the insulation that is not immediately evident, I had a broken one next to a terminal on the new loom I fitted to my GP resto project and didn't find it till first time out and I spluttered to a halt 3 miles from home, it took me an evening to find it as the continuity test didn't show it up straight away, it was only when I happened to move the wire being tested that I found the break, it wasn't visible under the plastic sheath.
sunrisemac
Re: None Runner
Postby Bilko » Sat Sep 27, 2014 2:08 pm
There goes Ballycastle next week. :(
Just finished going through everything again, swapping plugs, plug caps, HT leads, stators, CDI's, flywheels, checking wires, earths connections. Nothing.
Bilko
Re: None Runner
Postby Marty ULC » Sat Sep 27, 2014 3:03 pm
Mate I've a stator that I KNOW works (swapped it for a BGM for brighter lights) I'll drop it off tomorrow afternoon after work.
While I'm there we can pull the cdi off the bike I'm on and see if that works.
Marty ULC
Re: None Runner
Postby Captain Pugwash » Sat Sep 27, 2014 3:15 pm
You could try copious amounts of holy water and a priest to get the demons from hell within that beast of a scooter exorcised ? :twisted:
Captain Pugwash
Users browsing this forum: Baidu [Spider], Google [Bot] and 77 guests
