None Runner
Re: None Runner
Postby Wack » Wed Sep 10, 2014 5:46 pm
Don't forget to pressure test after
Re: None Runner
Postby CHRIS in MARGATE » Wed Sep 10, 2014 8:39 pm
I wonder if others think like myself?
Are there any assumptions being made with regard to the three necessary requirements?
Fuel, ignition, compression.
Fresh fuel, different carbs, fuel tap and breather.
No fuel filters fitted?
Worth a shot of Bradex Easy Start.
Ignition? Plug gapped; with correct feelers, plug cap, HT lead, swapped CDI and stator and flywheel. Woodruff key intact.
Have you measured frame earth to engine earth... Should be 0 ohms.
Consider isolating all junction and terminal boxes and connecting wiring straight through in case anything leaking to earth.
Compression: Different top end tried so gaskets new and no leaks.
You say the oil seals are OK but how have you established their integrity?
Aside from a crack taking in air in the bottom of the crankcase I would say one or more of the replaced/substituted components is faulty.
Trust me, I'm not criticising but I think there is something very basic missing here when you examine ....Fuel, Ignition, Compression. I wish I lived nearby !
Last edited by CHRIS in MARGATE on Wed Sep 10, 2014 10:07 pm, edited 1 time in total.
Re: None Runner
Postby Scooterlam » Wed Sep 10, 2014 9:24 pm
Same as chris,
Scooterlam
Re: None Runner
Postby Scooterlam » Wed Sep 10, 2014 9:29 pm
S
me as chris,
theres a great bit in Zen and the art of motorcycle maintenece, although written many years ago it could well be describing
This very thread.
Scooterlam
Re: None Runner
Postby coaster » Thu Sep 11, 2014 12:48 am
Eden wrote:Bilko is the kickstart shaft broken? :lol:
PSML :lol: :lol:
Re: None Runner
Postby Bilko » Thu Sep 11, 2014 3:20 pm
CHRIS in MARGATE wrote:I wonder if others think like myself?
I know you're not critisizing. I think there's something basic missing Chris, but I'm buggered if I knoqw what it is!!!
Bilko
Re: None Runner
Postby Bilko » Thu Sep 11, 2014 3:26 pm
Scooterlam wrote:S
me as chris,
This very thread.
You could be onto something...
I placed a few copies of Jet Set and lit an incense stick on it. :D
Bilko
Re: None Runner
Postby IaninDorset » Thu Sep 11, 2014 7:06 pm
Try a Feng Shui master in your garage, see if the improved harmony encourage the spirits to give it power... :P
IaninDorset
Re: None Runner
Postby Scooterlam » Thu Sep 11, 2014 8:31 pm
The zen part of the book was a bit over my head, but the bits relating to the thought processes required to problem solve
Were quite enlightening.
its a big old book but well worth a read.
Recomended by users of the old forum.
Scooterlam
Re: None Runner
Postby sunrisemac » Thu Sep 11, 2014 9:11 pm
spark plug's fallen out that's the problem.....
sunrisemac
Re: None Runner
Postby Bilko » Sat Sep 13, 2014 10:43 am
Mag housing off. partly grubby inside face, but nothing else. Crank out later.
Bilko
Re: None Runner
Postby Andyf » Sat Sep 13, 2014 8:06 pm
Scooterlam wrote:The zen part of the book was a bit over my head, but the bits relating to the thought processes required to problem solve
not all of them :oops: :oops:
Andyf
Re: RefusesI got the LI
Postby Bilko » Sun Sep 14, 2014 7:32 pm
berniek wrote:Have you checked the crank for alignment?
Took the crank out and the conrod has a good bit of play
Bilko
Re: None Runner
Postby CHRIS in MARGATE » Sun Sep 14, 2014 8:50 pm
Sideways or up and down. There is play normally sideways; just depends how much.
Re: None Runner
Postby Bilko » Sun Sep 14, 2014 9:42 pm
Up and down seems fine, but sideways does seem excessive and when I do the thump on the conrod with the palm ala Sticky's Manual, I do get a metal sound rather then a dull thud.
Bilko
Re: None Runner
Postby Bilko » Sun Sep 14, 2014 9:45 pm
Does this help any?
Bilko
Re: None Runner
Postby CHRIS in MARGATE » Sun Sep 14, 2014 9:54 pm
Looks normal to me.
Re: None Runner
Postby IaninDorset » Sun Sep 14, 2014 10:14 pm
Better than most Vespa cranks lol
But would this cause your failure I am wondering? Even with a little play I can't see how that would stop it running as the piston is going to be in the "zone" fairly well enough to maintain running I would have thought.
IaninDorset
Re: None Runner
Postby Captain Pugwash » Sun Sep 14, 2014 10:20 pm
Give it up its f###ed :lol:
Captain Pugwash
Re: None Runner
Postby Bilko » Sun Sep 14, 2014 11:54 pm
IaninDorset wrote:Better than most Vespa cranks lol
Me too.
Bilko
Users browsing this forum: No registered users and 87 guests
