HxPaul wrote:It begs the question,why dont they fit these new,after all in my opinion OMG are the best taps you can get............apart from this obvious fault.
Apparently they do.https://www.ebay.co.uk/itm/LAMBRETTA-RE ... SwpmNbKmXj
Scooterdude wrote:In fairness the scootopia one should be fine on a long range tank (providing you dont strip the thread).
Storkfoot wrote:Yes, thanks for the information. I am definitely going to check the flow rate though as I sometimes think I am too trusting in the blurb that accompanies products.
rossclark wrote:I had to buy a new tap yesterday at a local dealer and opted for the Scootopia one but the dealer also showed me a different all alloy OMG one, which I now wish I had bought, as I had to drain the tank again because the Scootopia one was running about 150mls a minute ... I'd filled the tank and it took over an hour to drain it...
On dismantling the tap I found that the inner plate with the tree holes in was rotated partially occluding the holes. Turned it round, reassembled and it flows 500ml in 49s - just goes to show how little it takes to cut the fuel flow to next to nothing
gaz_powell wrote:Scootopia sent me a new tap. Which I stripped to checked the rubber washer, it was okay so it's fitted
Will do some more miles and see what happens.
Rear exit OMG is on the shelf!
Fast n Furious wrote:gaz_powell wrote:Scootopia sent me a new tap. Which I stripped to checked the rubber washer, it was okay so it's fitted
I had this problem with a FF tap. The rubber disc was fine until it was subjected to petrol. I made a new disc from some neoprene sheet, and it's worked fine ever since.
Users browsing this forum: Baidu [Spider] and 60 guests
