Dell’orto K series needles
Postby Knowledge » Fri Jul 20, 2018 10:36 pm
Hi. I have three K series needles, but I ordered another needle from a kart dealer, and it is about 4mm longer.
The previous ones had five grooves, and the new one has four.
I have got to say, it runs much better on the new (longer) needle, but why two different lengths within the same range of needles?
Re: Dell’orto K series needles
Postby Norrie Bodge » Sat Jul 21, 2018 7:06 am
if you look at the chart m8, from K24 & below might expalin the longer needle?
Norrie Bodge
Postby Knowledge » Sat Jul 21, 2018 10:07 pm
Thanks Norrie, but I don’t think it is an explanation. Columns D and E are for multi-taper needles. The needle I have recently purchased is not multi-tapered: it is simply longer.
BTW, the needle chart now extends to 98 variants.
Postby Norrie Bodge » Sat Jul 21, 2018 11:27 pm
Didn’t realise 98 variants
Norrie Bodge
Postby Norrie Bodge » Sat Jul 21, 2018 11:34 pm
Matt cooper at eurocarb prob be a good bloke to email & ask about longer needles m8 -> sales@dellorto.co.uk
What needle is it you now using that’s longer & in what engine ?
I Just ordered a new K3 needle for the 32mm VHSA I use on a TS230
Norrie Bodge
Postby Knowledge » Mon Jul 23, 2018 1:50 pm
I have three (short) needles are something like, K22, K23 and K28. The "longer" needle I have just purchased is a K59 (I think).
I don't know if I need a longer needle, I was more surprised that a longer needle existed (and with a different number of grooves).
There is a hint in the explanation of needle K33, which translates as "differs from K27 to have a length of 70.5", which might indicate that longer needles have a place in the range.
98 needles. You can find the needle chart here (Thanks Eurocarb). https://www.dellorto.co.uk/wp-content/uploads/2015/06/K-U-Needle-charts.pdf
I printed it off, and the similar chart for X needles, and laminated them back-to-back.
Postby Norrie Bodge » Mon Jul 23, 2018 9:04 pm
thanks m8 that charts very handy, mind even more of a minefield
Norrie Bodge
Postby Adam_Winstone » Mon Jul 30, 2018 11:11 pm
Lots of dealers used to cut K needles to U needle length for use in VHSA carbs, whereas others used them at the full K length.
Postby Norrie Bodge » Tue Jul 31, 2018 10:49 am
Adam_Winstone wrote:Lots of dealers used to cut K needles to U needle length for use in VHSA carbs, whereas others used them at the full K length.
i bought a 32mm VHSA 2nd hand a few years ago & that had a shorter K5 needle fitted
what was the reason behind dealers shortening these m8?
Norrie Bodge
Return to Carburettors
Users browsing this forum: Bing [Bot] and 50 guests
