PHBH 26 jetting
PHBH 26 jetting
Postby Norfolk » Sat Jul 21, 2018 10:31 pm
Mugello 186. Ancillote exhaust.varitronic ignition
Dellorto PHBH 26 carburettor
Main 104
Pilot 48
Atomiser AV 266
Needle X7 second clip
Slide 40
Choke 70
Engine has always only idled at its best with both the mixture and idle screws both fully screwed in.
I have been checking several sites for recommendations of jetting and am now throughly confused
What are other people using please.
Norfolk
Re: PHBH 26 jetting
Postby ULC Soulagent » Sun Jul 22, 2018 3:02 pm
Mugello 186/
Ancillotti PHBH 26mm 26mm slide45 needleX4 atomiser AV264 main100 idle50 choke50 float 5gms 1 - 2 turns
ULC Soulagent
Re: PHBH 26 jetting
Postby Tony Hart » Sun Jul 22, 2018 3:41 pm
Mugello 186 with 42mm Ancilloti and 26mm PHBH
Main 105
Pilot 50
Choke 70
Slide 45
Atomiser AV 264
Needle X2 second slot from bottom
Remote filter
Tony Hart
Re: PHBH 26 jetting
Postby Rich Oswald » Sun Jul 22, 2018 4:20 pm
Norfolk wrote:Mugello 186. Ancillote exhaust.varitronic ignition
Main 104
Pilot 48
Atomiser AV 266
Slide 40
Choke 70
Jetting looks fine to me for your set up but something is definitely not right if both mixture and idle are screwed right in, especially mixture.
Re: PHBH 26 jetting
Postby shane BBoys » Sun Jul 22, 2018 8:53 pm
Could I ask is there any body out there running a 186 muggy with a reed valve set up? I found my mark 1 version stuck in the back of the garage from when there were no replacement pistons around anyhow I have match the reed valve and tidy up some areas and am looking at mating it with a 26 PHBH and a JL that was handed to me by a club member, so advice please.
Cheers Shane.
shane BBoys
Re: PHBH 26 jetting
Postby hullygully » Mon Jul 30, 2018 6:36 pm
Norfolk - you haven't said if its through your airbox or remote filter? :shock:
Return to Carburettors
Users browsing this forum: Bing [Bot] and 39 guests
