by Hughieboy » Tue Jul 17, 2018 7:30 pm
Hi,
My scooter seems to have developed an issue whereby it backfires when starting. It always starts but for some reason when you kick it over the kickstart immediately 'gives' and fires/backfires on the first time usually before it starts. Its an Li150 with a 190 top end, 30 mil Dellorto and Varitronic with a TSR Evo pipe. I recently checked the timing as I was getting heat seizures which is set at 19 degrees and retards down from there. Seemd ok but I still get heat seizures when cruising at 3/4 throttle.
Bit worried in case I bugger it! Hope someone recoginises this?
Hughieboy
by MickYork » Tue Jul 17, 2018 7:50 pm
19 seems a tad low as the Varitronic retards by 7 or 8 degree (i think ?). This would then retard to 11 or 12 degree which is very low, 16/17 being a "popular" running mark. This doesn't explain the backfire or the heat seizures but it's worth looking into.
have you done plug chops to checked your air/fuel ratio ?
by Hughieboy » Tue Jul 17, 2018 8:59 pm
19 is whats recommended by Cam Lam....
The plug looks ok, historically I've had an issue whereby 120 main jet runs smooth but I get heat seizes, 122 main bogs a bit but doesn't usually have the same heat seizing. Never had this backfiring though.
I wondered if there was a 'usual' cause of this issue....
Hughieboy
by MickYork » Tue Jul 17, 2018 9:32 pm
Could be an air leak, worth doing a leak test to eliminate that option
by Hughieboy » Tue Jul 17, 2018 9:46 pm
Thanks Mick...
I already did that too! Has a small leak at the exhaust port/manifold now fixed....
Hughieboy
by Fast n Furious » Wed Jul 18, 2018 1:12 am
There's not much meat left on a 190 cylinder. So, Your cooling needs to be spot on to prevent seizures.
Minimise the gaps where cooling air exits, which hasn't done any useful work.
It makes all the difference.
by Hughieboy » Wed Jul 18, 2018 7:13 am
Fast n Furious wrote:There's not much meat left on a 190 cylinder. So, Your cooling needs to be spot on to prevent seizures.
I hadn't thought of that.... I'll see what I can do, thanks.
Hughieboy
by Scooterlam » Wed Jul 18, 2018 8:18 pm
What's your start up regime?
Choke?
Twist of throttle as you kick?
fuel on or do you wait till it fires?
Scooterlam
by Hughieboy » Wed Jul 18, 2018 9:11 pm
Fuel on, choke (thumb choke), twist and kick.... Always done it the same...
Hughieboy
by Scooterlam » Wed Jul 18, 2018 10:28 pm
Probably takes a partially blocked pilot out of the equation.
ANTHONY Tambs has done lots of tests on various stator and reading his stuff stators can take up to 800 odd Rpm before they create a clean spark.
If it's something that's developed might be an issue with stator showing the first signs of being on the way out.
Personally for the small investment I would fit one of his external pick ups. But check they'd be compatible with your advance retard.
Scooterlam
by Hughieboy » Wed Jul 18, 2018 10:45 pm
Thanks..... but I hope there isnt anything wrong with it as it's a nearly new Varitronic, it's done less than 1000 miles. I'll look it up....
Hughieboy
by Mori63 » Wed Jul 18, 2018 10:48 pm
Hi, my varitronic started to do exactly the same a few years ago first kick it would misfire second kick it would start and I just lived with it ,then when in Normandy it started proper playing up ,it started as normal but then warmed up it was a right pain to start taking 30-40 kicks to get going it wanted to start but just wouldn't catch until you got lucky.the only advice I could find was try another stator plate ,I didn't have one or know anyone with a spare and new ones at over £200 i renewed the lot with BGM stuff .i know what I did won't really help you but I would say it sounds like the start of your stator braking down.
Mori63
by Hughieboy » Wed Jul 18, 2018 11:00 pm
Mori63 wrote:Hi, my varitronic started to do exactly the same a few years ago first kick it would misfire second kick it would start and I just lived with it ,then when in Normandy it started proper playing up ,it started as normal but then warmed up it was a right pain to start taking 30-40 kicks to get going it wanted to start but just wouldn't catch until you got lucky.the only advice I could find was try another stator plate ,I didn't have one or know anyone with a spare and new ones at over £200 i renewed the lot with BGM stuff .i know what I did won't really help you but I would say it sounds like the start of your stator braking down.
Wow.... that's disappointing considering how expensive it was. Probably bought it three years ago but I hardly ever ride the thing so it hasn't seen much action. To be honest, I've never been over impressed with it considering it was about £400 all up from memory as it's been a bitch to get the timing right on. What did you buy?
Hughieboy
by Scooterlam » Wed Jul 18, 2018 11:22 pm
Speak to th3 supplier, ask them how to check it.
If it is faulty there may have been a bad batch like the bgm's that wrapped themselves around the crank.
If not might be good to look up the same of goods act.
Fit for purpose and for a reasonable time.
I would argue £400 for a thousand miles isn't reasonable.
Remember you contract is with the supplier not the manufacturer
All a bit previous but I'd get the multi meter out and ask what readings you should be seeing.
Scooterlam
by Mori63 » Thu Jul 19, 2018 5:51 am
I had mine over ten years and was never really impressed with the lights ,BGM flywheel ,stator and CDI is what's on it now .
Mori63
by MickYork » Thu Jul 19, 2018 2:17 pm
I bought a second hand one and did quite a few thousand miles on it....no problems. I only changed to a "common" stator as i was concerned about breaking down away from home and no-one having a spare Varitronic stator/cdi/flywheel/etc.
Users browsing this forum: B1gD0gu3, Google [Bot] and 27 guests
