rossclark wrote:
I found a diagram that says the 'spare' white should go to earth and the two yellows should go to a small BGM style regulator, with output as a yellow to the loom, a red to the battery and a black to earth. I'm presuming that I can just connect the two yellows as they were from my old stator to the Wassel unit and leave the rest alone.
rossclark wrote:I'd have expected more wires for three phase, I've had it years but never got round to fitting it, originally came from Brolam but not sure if they're still trading?
The supplied reg looks very much like the BGM one - will see if it gives a clue and post a pic in the morning.
rossclark wrote:I think see what you mean - you'd need three (or six or nine) evenly spaced coils to generate the three pulses 120 degrees apart.
bsso78 wrote:Do you want to sell your original ignition?
