dscscotty wrote:pm sent
20181020_190115 by richardhenderson1968, on Flickr
20181020_190100 by richardhenderson1968, on Flickr
20181020_190154 by richardhenderson1968, on Flickr
20181020_190136 by richardhenderson1968, on Flickr
20181020_195143 by richardhenderson1968, on Flickrsteve t wrote:Looking good dickie what do you think to that front brake
HxPaul wrote:One of these will fit a battery in it and be better than fitting a capacitor https://www.ebay.co.uk/itm/Lambretta-Se ... %7Ciid%3A1
dickie wrote:
I used mypol inner tubes as I heard they were perfect fit; they're not. Or at least they're not with these stainless split rims. Maybe the valve hole is in the wrong place? Anyway, I'll use a michelin B4 tube as they're 90°. This tube will be ok for the front on my S3.2018-01-02_03-41-04 by richardhenderson1968
2019-02-05_09-36-05 by richardhenderson1968, on FlickrScooterdude wrote:I’ve rebuilt a few gearboxes and tend to use the MEC selector at around £75. Not worth taking the risk with the indian shite you get for £25, Scootopia or ina bearings and your good to go.
Not being critical but is that graph from after Chiselspeed fixed your gearbox? Something not right as it should make considerably more power than it shows there.
Scooterdude wrote:Yes a strange one as you’ve clearly had the cylinder tuned so would expect at least mid 20s.
Users browsing this forum: No registered users and 1098 guests
