bike grim wrote:Well he was at the Euro here in Spain on it
Solid Air wrote:bike grim wrote:Well he was at the Euro here in Spain on it
I saw Dave there and he said it was running well
Raveydavey wrote:Cheers a Mark. yesterday the CHT at 65ish mph was sitting about the 155 to 165 mark depending on whether I was going uphil, flat downhill etc. At 70 it rises to 180 if held there for long periods. Not sure how much hotter it'll go. Don't think I want to find out.
I might try a test: putting the choke on when I'm running at 65 and then taking it to 70/75 and holding it it a while to see how hot it gets.
Fast n Furious wrote:Raveydavey wrote:Cheers a Mark. yesterday the CHT at 65ish mph was sitting about the 155 to 165 mark depending on whether I was going uphil, flat downhill etc. At 70 it rises to 180 if held there for long periods. Not sure how much hotter it'll go. Don't think I want to find out.
I find the CHT values to be an arbitrary measurement at best.
My TS1/200 CHT sensor sits buried 3mm above the combustion bowl.
I think 310F is the maximum value I've ever seen on it.
I'm still non the wiser as to what the safe maximum value is, and suspect I would only find out after holing a piston (if I remembered to look at the gauge after costing to a stop!).![]()
My eyes are too old to read the bloody clock when riding anyway, and it has lost its accuracy as they all do after a few months of use because the stock RTD style sensor naturally suffers from stress drift.
Solid Air wrote:I might get the thin area built up with weld, not so much to make it structurally stronger but for a bit more gasket area.
Users browsing this forum: Google [Bot] and 39 guests
