ROClarke wrote:Got mine from VE and came next day.
Really looked foward to fitting it to my TS1, unfortunately as carb is right hand side,tool box has to go and the the rubber elbow is compressed by side panel when fitted
Ideas anyone ?
Fast n Furious wrote:I hope that 105 is a typo Tim?
Like Mick sez...... Very lean for a 225?
Fast n Furious wrote:ROClarke wrote:Got mine from VE and came next day.
Ideas anyone ?
With a TS1 you don't have to discard the toolbox.
There are aftermarket manifolds available to get around this issue, but a cheap way is to carefully and neatly dent inwards that bottom corner of toolbox that is causing the restriction with a suitable small hammer. A touch up to the paint work and all works well.
Unfortunately, the side panel issue is another matter. Just depends what carb you is using.
Bilko wrote:I'm wondering if one will fit my carb. There's only about a 1cm gap from the bottom of the carb to the side panel. Does anyone know the depth of the hose?
ROClarke wrote:Bilko wrote:I'm wondering if one will fit my carb. There's only about a 1cm gap from the bottom of the carb to the side panel. Does anyone know the depth of the hose?
The hose is 55mm deep, but you loose 10 mm pushing over the plastic bell on the dellorto carb.
Ideas anyone ?
ROClarke wrote:Fast n Furious wrote:Who or what would you recommend for the L/H manifold option ?
IMG_9655 by Nick Wilde, on Flickr
IMG_9776 by Nick Wilde, on Flickr
IMG_9782 by Nick Wilde, on FlickrUsers browsing this forum: B1gD0gu3 and 66 guests
