EP90 and LTH Clutch
EP90 and LTH Clutch
Postby Simon ELC » Wed May 30, 2018 10:19 pm
Anyone know if you can use EP90 gear oil with an LTH clutch?
I've been sent 5 litres by mistake.
Simon ELC
Re: EP90 and LTH Clutch
Postby rossclark » Wed May 30, 2018 10:24 pm
Isn't the problem with EP oils related to the phosphor bronze bushes rather than the clutch itself?
Postby Fast n Furious » Thu May 31, 2018 3:21 am
EP90 oil would be great for the gearbox, but Extra Pressure oils prevent the clutch plates from gripping properly leading to clutch slip.
ST90 is therefore specified as a satisfactory compromise.
Postby Tractorman » Thu May 31, 2018 7:16 am
Oiltek told me to use 85wt oil.
Postby Steve J » Sat Jun 02, 2018 11:03 am
rossclark wrote:Isn't the problem with EP oils related to the phosphor bronze bushes rather than the clutch itself?
The problem with bronze/copper/brass components and EP90 oils is that if the oil is to GL5 spec, the additives can attack the metal. EP oIls to GL4 spec are fine with bronze/copper/brass parts.
Steve J
Postby soullad » Sun Jun 03, 2018 12:13 am
Have used Rock Oil ST 90 in my engines that use LTH clutches and NEVER had an issue. Many many miles covered, no excessive component wear, clutch plates/ steels etc all great. I’ve carried a spare set of LTH clutch plates for 4 years and never had to use them !!!!
Great clutch, best out there IMO.
soullad
Postby Tractorman » Sun Jun 03, 2018 8:18 am
soullad wrote:Have used Rock Oil ST 90 in my engines that use LTH clutches and NEVER had an issue. Many many miles covered, no excessive component wear, clutch plates/ steels etc all great. I’ve carried a spare set of LTH clutch plates for 4 years and never had to use them !!!!
Got to agree with that. I have one in the sidecar some time without any problems.
