Which Head ?
Which Head ?
Postby St George » Tue May 22, 2018 4:18 pm
I recently gave my head and barrels an inspection. I was not happy with the head plug thread. I put on a standard AF Head and the engine don't seem to like it. I have polished ports, Jap Con-Rod with 3 mm packer and and a big bore Clubmans and 30 mm Carb. Can anyone suggest a sensible cylinder head for green lanes.
St George
Re: Which Head ?
Postby Knowledge » Tue May 22, 2018 7:10 pm
Why not get your original head helicoiled?
It will be a much stronger thread as a result.
Re: Which Head ?
Postby steve t » Tue May 22, 2018 9:18 pm
Knowledge wrote:Why not get your original head helicoiled?
Easy peasy
steve t
Re: Which Head ?
Postby St George » Thu May 24, 2018 4:03 pm
Thanks for replies but quite happy to order another head, busy time of year for me at work. Which head ? Ta :)
St George
Re: Which Head ?
Postby hullygully » Thu May 24, 2018 6:10 pm
AF's head............
did you check your squish?
is your piston a jap or a std curved crown?
Re: Which Head ?
Postby MickYork » Thu May 24, 2018 6:54 pm
Whichever head you get it should be profiled to the piston. Then, as said, check the squish.
You haven't said what your original head is ?
Shouldn't be a problem with the AF head if matched to the piston.
Re: Which Head ?
Postby St George » Fri May 25, 2018 5:49 pm
Thanks for replies, head went in the bin. Don't have a clue what it was as it came with the bike. The piston looks standard apart from a shortened skirt.
St George
