GT200 KIT
GT200 KIT
Postby pinboy65 » Thu May 24, 2018 9:36 am
For those considering a GT200 KIT who may not be aware you will need to fit off set cones. I have a kit fitted to a 68 SX200 and the manifold has taken paint off my frame, on inspection virtually nil clearance and on the carb side the lower jubilee clip holding the M.B rubber mount has taken even more paint off! I have a very good quality rear shock so that not the issue....
pinboy65
Re: GT200 KIT
Postby HxPaul » Thu May 24, 2018 10:17 am
How long is your rear shock? You will need one that is no longer than 300mm centre to centre.
Re: GT200 KIT
Postby roli150lam » Sat May 26, 2018 8:42 am
There is also the option for a right hand side manifold.Which gives more clearance on the frame,less clearance carb to sidepanel with sx type panels.
My carb is on the left side,offset cones and 300mm shocker.It's close but not touching/rubbing the frame.
roli150lam
Re: GT200 KIT
Postby burnside » Sun May 27, 2018 10:37 pm
No issues with my GT200 kit in my TV200, PHBH30 on LHS
burnside
Users browsing this forum: Google [Bot] and 51 guests
