Boggy Starter
Boggy Starter
Postby Granty » Wed May 09, 2018 8:38 am
Guys -- got a standard 200 lump, 42mm clubman & 26mm jetex, just rebuilt top end, carb been stripped cleaned etc, weird one this, when it starts it is very, very boggy, I have to have choke off, throttle wide open and I keep kicking until it bites, when it does bite it picks up very, very slowly and gradually the beats pick up fine & no problem. The jetting is 26mm jetex carb (reemed), GP 200 Slide, 5899-2 atomiser, 123 main jet, 50 pilot & 50 choke.
Am I thinking that lowering the pilot jet to a 48 etc may work? Any ideas guys?
Granty
Re: Boggy Starter
Postby ULC Soulagent » Wed May 09, 2018 10:00 am
Try it with the air filter off and see what it does
ULC Soulagent
Re: Boggy Starter
Postby CHRIS in MARGATE » Wed May 09, 2018 5:42 pm
Sounds like choke plunger stuck.
Re: Boggy Starter
Postby St George » Wed May 09, 2018 6:02 pm
Stick a new plug in, never know ?
St George
Re: Boggy Starter
Postby rossclark » Wed May 09, 2018 6:16 pm
Try first with the air filter hose off. If that improves it try drop the main a little - say 118 and try with the filter on and see if it's any better.
Re: Boggy Starter
Postby MickYork » Wed May 09, 2018 7:55 pm
CHRIS in MARGATE wrote:Sounds like choke plunger stuck.
+1
Re: Boggy Starter
Postby Feersum Injun » Thu May 10, 2018 8:12 am
+1
my first thought as well.... or needs readjusting
Feersum Injun
Re: Boggy Starter
Postby hullygully » Thu May 10, 2018 6:01 pm
pilot & air flow
Re: Boggy Starter
Postby Granty » Sat May 12, 2018 1:13 pm
Thanks Guys -- a lot to be getting on with -- I'll start with the choke plunger I think, maybe just flooding the carb straight off the bat, when it does fire it's like it ticks over in slow motion gradually building up to the correct tick over -- once it's up to normal tick over goes great.
Granty
Re: Boggy Starter
Postby Scooterdude » Sat May 12, 2018 3:24 pm
Im just in the middle of one displaying exactly the same symptoms. Swapped carb over this morning for an identical one i have hear to rule that out.....exactly the same. Im thinking stator now, let you know later.
Scooterdude
Re: Boggy Starter
Postby Scooterdude » Sat May 12, 2018 6:03 pm
Scooterdude wrote:Im just in the middle of one displaying exactly the same symptoms. Swapped carb over this morning for an identical one i have hear to rule that out.....exactly the same. Im thinking stator now, let you know later.
Yes it turned out to be the stator so all fixed now.
Scooterdude
Re: Boggy Starter
Postby Granty » Sat May 12, 2018 7:44 pm
mmm - The plot thickens, mine has done this with 2 x stators with the new BGM one only 12 months -- I thought for a second that could have been it but looked back through the timeline. Originally I thought it was just worn rings but I've renewed them also -- weird.
Granty
Re: Boggy Starter
Postby Scooterdude » Sat May 12, 2018 8:08 pm
Have you checked your pick up alignment?
Scooterdude
Re: Boggy Starter
Postby Granty » Sun May 13, 2018 9:50 am
No mate, not checked that, been thinking through this issue & it was prevalent when trying to hot start after some hefty rally miles, I thought it was the rings so changed them, it's happened over the lifetime of 2 x stators and now it's started when cold starting -- I'll get my head into this & feedback
Granty
Return to Carburettors
