Cuts out
Re: Cuts out
Postby bike grim » Wed Apr 25, 2018 4:09 pm
Ouch
Re: Cuts out
Postby Raveydavey » Wed Apr 25, 2018 5:51 pm
Marty ULC wrote:Ring peg has come out, left a deep gouge on the inlet side and looks like it's pushed the piston against the opposite wall of the barrel fusing the rings into their grooves.
Less than 3.5 thousand miles on the kit. :cry:
I feel your pain.had that happen on 2 kits in 12 months. 1 RT225 and the other, an Avanti TT which decided to go en route to the euro last year. Good luck getting it sorted
Raveydavey
Re: Cuts out
Postby hullygully » Wed Apr 25, 2018 6:41 pm
deep breaths Marty, as above we've all being there :cry:
Re: Cuts out
Postby coaster » Wed Apr 25, 2018 8:43 pm
I thought they had sorted the problem with ring pegs coming out, is yours an early kit?
Re: Cuts out
Postby Marty ULC » Wed Apr 25, 2018 8:44 pm
I'm going to take it to a local bike shop to see if it's salvageable. Once we know the oversize where do I find the recommended piston to bore clearance for the kit?
Marty ULC
Re: Cuts out
Postby Marty ULC » Wed Apr 25, 2018 8:45 pm
Thought that was the RT kits, this is a GT.
Marty ULC
Re: Cuts out
Postby bike grim » Wed Apr 25, 2018 8:52 pm
Yep. +1 Mine went on the way to the Euro last year as well. (Pro Porting 283 with a jet ski piston) trashed the piston, the barrel and the crank!!
Re: Cuts out
Postby CHRIS in MARGATE » Wed Apr 25, 2018 10:08 pm
So what about the original poster Kilsh 1968 ?. Is that problem fixed ?
Re: Cuts out
Postby coaster » Wed Apr 25, 2018 10:22 pm
CHRIS in MARGATE wrote:So what about the original poster Kilsh 1968 ?. Is that problem fixed ?
I was thinking the same thing Chris, I couldn't figure how we got from a 4th oversize Jet 200 to a buggered GT kit until I checked the posters names :?
How are we doing Kilsh, any further with it?
Re: Cuts out
Postby Marty ULC » Wed Apr 25, 2018 11:57 pm
Sorry for the thread hijack.
I thought I had the same problem at first so didn't want to start a new thread for the same subject. :oops:
Marty ULC
Re: Cuts out
Postby Feersum Injun » Thu Apr 26, 2018 7:58 am
What kit?
Feersum Injun
Re: Cuts out
Postby Feersum Injun » Thu Apr 26, 2018 7:59 am
Sorry... just seen it was a GT
Feersum Injun
Re: Cuts out
Postby Feersum Injun » Thu Apr 26, 2018 8:08 am
Here's my RT after dropping a peg at the Derby150 last year. I'd had the kit since 2013 but the piston was newish and had only been in a year but was the old type. MB replaced the kit which I thought was excellent service... good luck...
ImageIMG_8027 by Nick Wilde, on Flickr
Feersum Injun
Re: Cuts out
Postby kilsh1968 » Sat Apr 28, 2018 12:05 pm
Well just received getting myself together have bought new cdi new fast flow tap have new regulator and stator just got my mate to make room then we will have a look thanks for all help
kilsh1968
Re: Cuts out
Postby kilsh1968 » Wed May 02, 2018 5:53 am
Have changed stator tooknoff fast flow with warning and put fast flow and new fuel pipe on have new cdi but gonna try first scooter started first kick sounds sweet run nice just need to do a few miles and hopefully not get the blurrrrand stop keep u posted but you never can tell when it could happen
kilsh1968
Re: Cuts out
Postby Tony Hart » Wed May 02, 2018 8:01 am
Result!
Tony Hart
Re: Cuts out
Postby CHRIS in MARGATE » Wed May 02, 2018 9:12 am
Good result but you'll never know which component was faulty now. Which one are you going to bin, or will you do what we all do and put them both in a drawer?
Re: Cuts out
Postby kilsh1968 » Wed May 02, 2018 10:26 am
In the draw as don’t know if cured till the next time lol thanks men
kilsh1968
Re: Cuts out
Postby kilsh1968 » Wed May 02, 2018 9:24 pm
The only think I’m not sure about when my mate rebuilt the engine it cut out first ride round the block could that lave been the new stator which ?or flow from the fast flow tap which I have replaced ??
kilsh1968
Re: Cuts out
Postby kilsh1968 » Mon May 28, 2018 3:07 pm
Rode 15 miles times x2 ways today seemed fine on way back spluttered about a bit thought oh fuck then used the old foot on to reserve and seemed ok pulled in to station put 5-75 litres in at 3% fully Simfetic ok after that was that right to be on reserve with 2 litres left in tank ?? So still need to give it a longer run to see if she cuts out fingers crossed
kilsh1968
