Framebreather engine casings
Postby bike grim » Tue May 01, 2018 3:43 pm
I’ve just stripped a standard 1958 150 series 1 framebreather engine. I’m aiming to kit it. I’ve heard various things over the years about not using the standard mag housing but using a later one due to the single seal and petroil lubrication, and also about getting the casing machined on the drive side to fit an oil thrower washer etc but lately have had info from members that there is no need to do that. If that is the case and I use a gp crank, do I just order normal bearings? Are the seals available ? Any guidance would be appreciated.
Thanks Gareth
Re: Framebreather engine casings
Postby ULC Soulagent » Tue May 01, 2018 4:21 pm
As far as I'm aware, tuner Charlie Edmonds used S1 mag housing as the slot aided lubrication on his super monza's.
Not sure on the oil dish washer as I ain't heard or seen it being done.
ULC Soulagent
Postby Raveydavey » Tue May 01, 2018 5:50 pm
ULC Soulagent wrote:As far as I'm aware, tuner Charlie Edmonds used S1 mag housing as the slot aided lubrication on his super monza's.
Not just Super Monzas. A friend of mine has fitted one to a GP 200 case running a Mugello at the advice of Charlie.
My quattrini is mounted in a complete framebreather case. The only modification is the huge amount of metal taken away from the transfers. :P Martin Cook @ Chiselspeed said he has run race engines with S1 casings including Mag housing.
Raveydavey
Postby bike grim » Tue May 01, 2018 6:04 pm
Dave that’s what I mean, when you told me I just thought I’d check on it. Wonder if Martin stocks the bearings and seals then? Makes sense I suppose. But are they the same sizes etc as we normally use in other builds?
Postby bike grim » Tue May 01, 2018 6:05 pm
Cheers S
Postby Raveydavey » Tue May 01, 2018 10:06 pm
bike grim wrote:Dave that’s what I mean, when you told me I just thought I’d check on it. Wonder if Martin stocks the bearings and seals then? Makes sense I suppose. But are they the same sizes etc as we normally use in other builds?
No worries Gareth. I'll be at chiselspeed tomorrow so will ask Martin for you.
Raveydavey
Postby bike grim » Tue May 01, 2018 11:00 pm
Brill, Cheers
Postby Warkton Tornado No.1 » Wed May 02, 2018 12:04 pm
bike grim wrote:I’ve just stripped a standard 1958 150 series 1 framebreather engine. I’m aiming to kit it. I’ve heard various things over the years about not using the standard mag housing but using a later one due to the single seal and petroil lubrication, and also about getting the casing machined on the drive side to fit an oil thrower washer etc but lately have had info from members that there is no need to do that. If that is the case and I use a gp crank, do I just order normal bearings? Are the seals available ? Any guidance would be appreciated.
Thanks Gareth
My belief is that the use of ANY magneto housing & the use of seals & the various bearings that fit is nowadays determined by what the engine builder thinks of primary compression. A standard nitrile outer seal will be fine, though I know some Forum users would prefer to spend more on so-called better seals. I've yet to experience a seal failure as the result of modern fuels.....
If a lower primary compression is desired, say, as might be the case in a racing engine with a good expansion chamber, then omitting the inner seal & ensuring good bearing lubrication with sufficient oil/air ways will enable the later magneto housings to be utilised.
A standard NU type roller bearing will cope & I see no reason as to why the earlier type roller bearing would not also be fine. Some racing engine builders use a specific 'magneto bearing' (a ball bearing) but there are, as ever, varying opinions as to whether the crankshaft is allowed to flex, or not, but the roller bearing type is far stronger in terms of dynamic load capability & the durability, an important consideration with a road engine.
I hope that helps ;)
Users browsing this forum: No registered users and 76 guests
