air filter
air filter
Postby Gary les » Wed Apr 25, 2018 1:42 pm
how many are running a ts1 35 tmx with out a air filter and panel on no hole
Gary les
Re: air filter
Postby hullygully » Wed Apr 25, 2018 6:37 pm
me & a couple of buddies, no probs, still runs richer than without cans on
Taffspeed years ago recommended just a 10mm hole near to the centre of the carb in the side can 8-)
Re: air filter
Postby Fast n Furious » Thu Apr 26, 2018 12:12 pm
Not a good idea to run TS1's and RB's without an air filter of some description.
Your flywheel is good at sucking up all the nearside road detritus. It then fires this grit around the cylinder where it then exits from the cowling aperture on the far side, right in front of the carburettor intake.
Big mistake and costly.
Re: air filter
Postby MickYork » Thu Apr 26, 2018 5:13 pm
An air filter will help to prolong the life of the lining. Small particles will act as an abrasive and increase the wear of the lining. This could half the wear life of the barrel.
be smart and fit a filter....next to nowt in difference in performance..I dynoed 23hp with a filter and 22.5hp without
Re: air filter
Postby Gary les » Sun Apr 29, 2018 6:48 am
just ordered one of these new panel filters from chieselspeed see how this works
Gary les
Re: air filter
Postby shane BBoys » Sun Apr 29, 2018 7:08 am
Gary les wrote:just ordered one of these new panel filters from chieselspeed see how this works
Please keep us informed, i was considering 1 of these too!
Cheers Shane
shane BBoys
Re: air filter
Postby Gary les » Sun Apr 29, 2018 6:32 pm
Spoke to chisel speed and he was raving about it,at £16.95 it cheap got a filter with the elbow of the tmx35 and top end restricted see if it make any difference
Gary les
Re: air filter
Postby shane BBoys » Fri May 11, 2018 5:01 pm
Seeing as I'm only in Bradi Stan I thought I would nip over to Chisel and purchase 1 of these and so far I have spotted no difference in power what so ever.
TS1 35mm TMX with an old NK (which rattled loose again) now nailed back on.
travelled across to Halifax on the motorway and clocked 75MPH up the hill from Brighouse to HX.
Cheers Shane.
shane BBoys
Re: air filter
Postby ROClarke » Fri May 25, 2018 4:43 pm
shane BBoys wrote:Seeing as I'm only in Bradi Stan I thought I would nip over to Chisel and purchase 1 of these and so far I have spotted no difference in power what so ever.
Cheers Shane.
Never where that accurate,Lambretta Speedo's :D
ROClarke
Re: air filter
Postby shane BBoys » Thu May 31, 2018 9:51 pm
Correct so i use GPS.
Managed to get 78.8 coming back from Kelso. Exhaust is rattling again, bloody NK,s.
Cheers Shane
shane BBoys
Re: air filter
Postby ROClarke » Fri Jun 01, 2018 9:47 pm
shane BBoys wrote:Correct so i use GPS.
Cheers Shane
That's pretty good,did 74 on mine recently coming back from flying eight balls rally, loaded up with camping gear as well :)
ROClarke
Return to Carburettors
