Li Brake Shoes on GP Hub?
Postby davla » Thu Apr 12, 2018 11:55 pm
Is there any reason why I can’t use Li brake shoes on a GP front hub back plate?
davla
Re: Li Brake Shoes on GP Hub?
Postby HxPaul » Fri Apr 13, 2018 9:25 am
I use Makino (Indian) on an Italian Li,so I dont see any reason why not.
Postby Adam_Winstone » Fri Apr 13, 2018 2:36 pm
LI and SX cam is a different thickness, with shoes differing to suit. If you want to interchange then you need to swap out the cam too.
Adam
Postby davla » Fri Apr 13, 2018 2:56 pm
Cheers for the replies, I should be ok then as I'm just transferring all of the moving parts from and early 'weak' backplate to a GP backplate. I'd dry assembled it before dropping off to the powder coaters and it all seemed fine but just thought I'd check in case I'd missed something.
davla
Postby St George » Fri Apr 13, 2018 5:37 pm
I think the SIL GP 200 take LI Shoes from memory, I bought some a couple of years ago from an established dealer.
St George
Postby Scooterlam » Wed Apr 18, 2018 9:46 pm
I'm sure I've had universal shoes that came with a clip on shim so usable with both cams.
Scooterlam
Postby HxPaul » Thu Apr 19, 2018 9:36 am
These are the type that I use,but I note that these are for Li,SX type brakes,so as Adam says there must be some difference in the cam.http://www.scooterrestorations.com/lamb ... ir-makino/
Users browsing this forum: Bing [Bot] and 19 guests
