Ignition switch
Ignition switch
Postby gazzar15 » Mon Apr 09, 2018 7:13 pm
I bought an ignition switch for my series 3 ...it is quite bulbous and does not match the curve at the rear of my headset .Is there a more slimline version available?
Without taking some metal out of the casing of the thing it just will not fit...
gazzar15
Re: Ignition switch
Postby Norrie Bodge » Mon Apr 09, 2018 7:48 pm
CASA or Scootopia
where did you buy the current one?
Norrie Bodge
Re: Ignition switch
Postby dickie » Mon Apr 09, 2018 8:13 pm
If it's a common or garden li125 or 150, I think that you need to get busy with the dremmel as they only had cut out switches from the factory.
Re: Ignition switch
Postby gazzar15 » Mon Apr 09, 2018 9:22 pm
Not certain where I got it fromBeadspeed I think but would need to check
gazzar15
