V force reeds
V force reeds
Postby Psychedelicropcircle » Mon Apr 09, 2018 9:24 am
Anyone using these on an imola cylinder?
Re: V force reeds
Postby ULC Soulagent » Mon Apr 09, 2018 9:54 am
Wont fit I believe,
ULC Soulagent
Re: V force reeds
Postby Psychedelicropcircle » Mon Apr 09, 2018 3:19 pm
It’s an older version that can get a TS reed block in? Only mentioning this as I assume the newer versions reed area may be smalller?
Re: V force reeds
Postby ULC Soulagent » Mon Apr 09, 2018 7:09 pm
Could well be then, only used the new mk4 version
ULC Soulagent
Re: V force reeds
Postby Psychedelicropcircle » Sun Jun 03, 2018 10:56 am
Managed to track down a set from chiselspeed. Those that use v force in a TS does it need a packer?
Re: V force reeds
Postby gp200ts1 » Sun Jun 03, 2018 11:32 am
Mbd modified my Monza barrel to take a v force 4 when he tuned the barrel, no packer fitted as it doesn’t mask the boost port.
gp200ts1
Re: V force reeds
Postby Psychedelicropcircle » Wed Jun 06, 2018 3:56 pm
It’s a v3 I’m using on a MB tuned imola so I’d imagine it won’t need one. I’ll be sure to check the boost port area!
Users browsing this forum: Baidu [Spider] and 71 guests
