kick start
kick start
Postby kennystag » Sat Mar 31, 2018 8:51 pm
Hi All,
Are the kick starts all the same for123,and GP models. Looking for one for my series 3 LI.
Stag
kennystag
Re: kick start
Postby rossclark » Sat Mar 31, 2018 9:37 pm
No, some S1 and S2 have an 'outie' stop on the side casing and a different shaped pedal.
All S3 should be interchangeable but some are longer than others.
Re: kick start
Postby coaster » Sun Apr 01, 2018 10:56 am
rossclark wrote:.....All S3 should be interchangeable but some are longer than others.
Innocenti made the top part thicker by about 2mm at the point where they kept fracturing when they introduced the GP. The extra thickness required the ally boss in the side case to be machined down by the same 2mm amount. Many S2 and 3's will have had this mod done already as the GP shaft was all that was available, in which case a GP shaft will be fine but best measure the one you already have before ordering a new one
Re: kick start
Postby Donnie » Sun Apr 01, 2018 2:43 pm
Seems one of you is talking about the pedal and one about the shaft, to be fair its not 100% clear which Kenny is talking about.
Donnie
Re: kick start
Postby ToBoldlyGo » Sun Apr 01, 2018 4:53 pm
Internally the GP differs from the other S3's. It has a built in ramp on the endplate and doesn't have the adjustment. Externally all S3 kickstart pedals are interchangeable, for all intents and purposes. But the S2 kickstart is shorter and designed to fit wider footboards.
ToBoldlyGo
Re: kick start
Postby coaster » Sun Apr 01, 2018 7:09 pm
ToBoldlyGo wrote:Internally the GP differs from the other S3's. It has a built in ramp on the endplate and doesn't have the adjustment. Externally all S3 kickstart pedals are interchangeable, for all intents and purposes. But the S2 kickstart is shorter and designed to fit wider footboards.
Reading the OP again, I think you are right, Kenny is talking about the lever :oops:
Re: kick start
Postby ToBoldlyGo » Sun Apr 01, 2018 10:40 pm
I was covering my bets. :lol:
ToBoldlyGo
Re: kick start
Postby myjiffey » Sun Apr 01, 2018 11:06 pm
And then you have the arm for the Spanish S2 TV175 ,another oddball
myjiffey
Re: kick start
Postby rossclark » Mon Apr 02, 2018 12:00 am
And the short straight Lince one, but thought the likelihood of turning one of those up was quite small...
Re: kick start
Postby HxPaul » Mon Apr 02, 2018 8:41 am
Re: kick start
Postby terryj » Tue Apr 03, 2018 7:34 am
the problem i have with kickstarts is finding one where the splines line up to give a long kick
best i have have is an old rusty as hell indian one
terryj
Re: kick start
Postby kennystag » Wed May 02, 2018 4:26 pm
I bent the kick start to give it more travel , works a treat.
Stag
8-)
kennystag
Re: kick start
Postby kennystag » Tue Aug 07, 2018 8:12 am
Hi All,
I just read this post again, it is the kick start lever I was taking about. Sorry if I did not make myself clear.
Stag
:oops:
kennystag
Re: kick start
Postby HxPaul » Tue Aug 07, 2018 9:21 am
kennystag wrote:Hi All,
Stag
The kickstart levers are different on the series 1 and early series 2.The kickstart spline on these machines dont have a break in the middle and the later series 2 and the series 3 kickstart lever bolt wont fit.
Users browsing this forum: No registered users and 55 guests
