roli150lam wrote:Did you take the green wire off the cdi?
Should be two green wires,take the one that comes from the loom off.
If it starts then its probably the cdi thats u.s..
Paul_from_Thornbury wrote:LT coil failed. Reading 50 ohms.
This is my 3rd BGM LT Coil as well as having two BGM stators fail pick-ups as well.
Appreciate that Lukas wont help my previous pick up failures. Think I'm going to stick a Scooter Restorations Indian Stator in next time around when the engine is next out.
HxPaul wrote:I have known LT coils to fail,but I've never heard of a case of a pickup failing,although it must happen,its just that I have not heard of one
Paul_from_Thornbury wrote:.............Are these supposed to be get you home devices or use at all times?
Paul_from_Thornbury wrote:Reedspeed diagram is wrong. It shows Stator yellow and Lukas CDI on same input to regulator. This is wrong. Stator on input and Lukas on output is correct.
See new post however, as now operating the horn cuts out the engine.
Users browsing this forum: Google [Bot] and 81 guests
