New gear boxes
Re: New gear boxes
Postby Scooterlam » Mon Mar 12, 2018 12:03 am
does any one have the formula for calculating gear ratios,used be on here years ago.
Scooterlam
Re: New gear boxes
Postby Adam_Winstone » Mon Mar 12, 2018 12:08 am
Re: New gear boxes
Postby Scooterlam » Mon Mar 12, 2018 12:38 am
On that adam but doesn't help.
Need to work out AF5 with different primaries.
Scooterlam
Re: New gear boxes
Postby Scooterlam » Mon Mar 12, 2018 1:35 am
Loose Gear Divided By Gear Cluster) x (Rear Sprocket divided by Front Sprocket
Scooterlam
Re: New gear boxes
Postby bike grim » Mon Mar 12, 2018 9:43 am
Look at the Tony Cassidy gear box visualiser. all the new boxes are on there.
https://avantone.files.wordpress.com/20 ... er_v5.xlsx
Re: New gear boxes
Postby Scooterlam » Mon Mar 12, 2018 8:16 pm
Scooterlam
Re: New gear boxes
Postby Scooterlam » Sat Mar 24, 2018 5:38 pm
does anyone know if AF sell the loose 5th gear separately?
Scooterlam
Re: New gear boxes
Postby Tony Hart » Sat Mar 24, 2018 5:53 pm
Just seen elsewhere that there has been an issue with an AF box at Mallory Park yesterday and they are not selling any more until they have assessed. The failure was on a very high BHP engine. Update is on SLUK.
Tony Hart
Re: New gear boxes
Postby Scooterlam » Sat Mar 24, 2018 7:24 pm
just saw that,
shame.
Still the Wife is quite pleased as I was about to order one :cry:
Scooterlam
Re: New gear boxes
Postby Solid Air » Sat Mar 24, 2018 7:33 pm
That is a shame but good to see AFR being open and honest. Fingers crossed it's sorted soon.
Re: New gear boxes
Postby Jim Rose » Sun Mar 25, 2018 6:27 am
I'm just about to fit one of the Robbospeed ones £600 plus fitting. It's going in my 30+ BHP Targa. I'm using the same ratios up as Martin Robinson as I want a fast tourer I'll post results when I've been on the road for a bit
Jim Rose
Re: New gear boxes
Postby Scooterlam » Sun Mar 25, 2018 7:30 pm
Got a link,
Scooterlam
Re: New gear boxes
Postby petemaisey » Mon Mar 26, 2018 10:12 am
petemaisey
Re: New gear boxes
Postby Watfordwhite » Mon Mar 26, 2018 7:14 pm
Well done to AF for the recall, but gutted as I wanted one in my MQ210
Watfordwhite
Re: New gear boxes
Postby corrado » Wed Mar 28, 2018 12:42 pm
bike grim wrote:Look at the Tony Cassidy gear box visualiser. all the new boxes are on there.
This is by far the best source of gearing info, particularly the ability to compare 2 gearboxes side by side. Be honest with the quoted BHP figures though.
corrado
Re: New gear boxes
Postby Scooterlam » Thu Apr 19, 2018 7:50 pm
AF are still selling Clo5e gear boxes. and the sell 5th separately in case your a bit too optimistic.
Scooterlam
Re: New gear boxes
Postby Scooterlam » Wed May 02, 2018 3:09 pm
Took the plunge on the Clo5e box and started fitting yesterday.
The instructions are comprehensive and have colour photos if they're available on line I would read them before ordering as it will help in deciding what other bits you night need.
I did a straight swap with all bearings and layshft reused.
Partly because I've heard horror stories of incomparable shaft and bearing combos.
I've got it in and clutch chain and sprocket fitted.
As AF said shim down a mm and it all went in first time no issues.
Hopefully no kick start ramp issues (Indian GP endplate)
So far impressed.
Scooterlam
Re: New gear boxes
Postby coaster » Wed May 02, 2018 3:32 pm
Scooterlam wrote:.............Hopefully no kick start ramp issues (Indian GP endplate)
So far impressed.
Should have sawn that ramp off while you had the end plate out, they are made of very soft cast iron and a hacksaw will deal with it in less than a minute. Drill and tap 3 6mm holes in the casing and jobs done 8-)
Re: New gear boxes
Postby Scooterlam » Wed May 02, 2018 9:18 pm
I know,
Kick start engages a little lower than I hoped for. Side stand will help and it only needs a prod to fire.
Just hoping for a straight swap over.
Euro getting nearer just don't need problems.
Switchable dc ignition running off battery alongside a.c is next job
Then some brakes would be nice.
Optimistically geared for 4.31 with 12% 5th. Fully revved out on 4.6 4 speed so hopeful.
Should give close to 90 mph which is the speed my mate reckons it does now according to his 2016 bike Speedo. But I know it's 83mph.
Scooterlam
Re: New gear boxes
Postby Jim Rose » Thu May 03, 2018 5:32 am
Done a few hundred miles on my new Robbospeed 5 speed gearbox. Easy to fit and I got what I wanted a very fast tourer now. May have to change the front sprocket for Spain because I'll be two up for some of the trip and the ratio is tall.
Jim Rose
