which carburetta?
which carburetta?
Postby WOO » Wed Mar 07, 2018 7:56 pm
Can anyone help please with carb choice for my restoration
With a 175 conversion (with an iron head) of a 1960 series 2 LI125
which carb would be the best to use
is the jetex s100 22mm any good
WOO
Re: which carburetta?
Postby Watfordwhite » Wed Mar 07, 2018 9:37 pm
I have a 28mm Deli on mine, but it has been heaverly tuned. Runs great.
Watfordwhite
Postby ToBoldlyGo » Wed Mar 07, 2018 9:57 pm
I'd go for a 20mm carb personally. Perfect for a 175 top end. Probably finish it off with a standard exhaust.
ToBoldlyGo
Postby Meds » Wed Mar 07, 2018 11:30 pm
I can only give my personal experienc of Jetex carbs.
I have always has trouble with them.
There are many on here who can get them to work fine, I never could.
The scootopia 22mil carb is suppose to be quite good, but never used them.
Meds
Postby WOO » Thu Mar 08, 2018 10:02 am
thanks meds, which one do you use?
WOO
Postby kennystag » Thu Mar 08, 2018 10:33 am
Hi WOO,
scootopia 22 mm carburettor, Ebay item number 152933890808 or any ware else, I have not had any problems with the 22 mm scootopia carb.
Stag
kennystag
Postby kennystag » Thu Mar 08, 2018 10:37 am
Woo I forgot to say I have the same set up as you have with the 175 top end on my GP 150.
Stag
kennystag
Postby WOO » Thu Mar 08, 2018 2:31 pm
cheers, will have to get a scootopia carb,
WOO
Postby HxPaul » Thu Mar 08, 2018 4:15 pm
WOO wrote:cheers, will have to get a scootopia carb,
viewtopic.php?f=6&t=7900&p=77252&hilit=float#p77252 10 posts down
Postby HxPaul » Sat Mar 10, 2018 4:48 pm
Fitted a genuine dellorto float.From seam to seam its 1/2mm thinner than the scootopia float,side to side and back to front.
Postby Meds » Sun Mar 11, 2018 9:07 am
I’m using dell or to PHBH 28 and a 30.
Meds
