I had never seen this before on an S3
Postby foremanbob » Mon Mar 05, 2018 4:48 pm
Stripping and rebuilding an S3, Li125.
The rear running plastic strips have 2 bolts at the dog leg frame struts, two holes on the foot boards, and 1 1/2 holes in the dogleg struts (almost like they were S2 doglegs cut short to suit the narrow width)
Trying to source the rear running strips to match and cant find any... any suggestions? The nuts were so badly rusted on that they had to be cut off.
foremanbob
Re: I had never seen this before on an S3
Postby Storkfoot » Mon Mar 05, 2018 5:05 pm
Yours must be an early series 3. It’s a long time since I had one but, from memory, standard S3 plastic strips fit.
Postby ToBoldlyGo » Mon Mar 05, 2018 7:41 pm
Yes, as Storkfoot says, early S3. Bit of overkill really. You only need the one. Later strips will fit and cover the second hole.
ToBoldlyGo
Postby HxPaul » Tue Mar 06, 2018 10:29 am
Theres a picture of the dogleg of an early series 3 in stickys manual,second edition on page 157.
Postby foremanbob » Tue Mar 06, 2018 12:02 pm
Thanks chaps... every day is a learning day
foremanbob
Users browsing this forum: Google [Bot] and 40 guests
