HxPaul wrote:Would I be right in saying that you cant buy off the shelf lower tapered roller bearings,I've looked everywhere and there these bearings are load bearing.If you want taper rolling lower bearings you have to make them.
HxPaul wrote:Its not the bearings themselves,but the outer bearing races that are not available.
Fast n Furious wrote:I think I used a 32006 which has a slightly smaller OD. and width.
TED CRUD wrote:Where do you get a replacement dust cover for the top bearing ?
Users browsing this forum: Baidu [Spider] and 85 guests
