"quiet" bigbore standard exhaust?
Postby peejay » Thu Mar 01, 2018 1:46 pm
hi peeps
i'm running a standard RT 225 kit with 30mm carb with ramair filter.
exhaust is currently an oldish AF bigbore clubman, it is still in good condition although has done many thousands of miles but is rather noisy.
i'm looking for a genuinely fairly quiet big bore box to replace it. i really want the standard type lammie "rasp" exhaust note, not the expansion pipe "crack" which sends all the New Forest ponies in a 10 mile radius off in panic mode.
i'm willing to sacrifice a bit of performance for a quiet life
your suggestions welcome :)
PeeJay
Re: "quiet" bigbore standard exhaust?
Postby ULC Soulagent » Thu Mar 01, 2018 2:26 pm
Just get another af clubby or scootopia clubby, cheap cheerful and a lot less noisy than bgm, Gori etc etc
ULC Soulagent
Postby HxPaul » Thu Mar 01, 2018 2:45 pm
This is the nearest to original in looks and sound,it has the "mushroom baffle".Not cheap though. http://www.scootopia.co.uk/product/7188 ... ipe--clamp
Postby peejay » Thu Mar 01, 2018 3:48 pm
HxPaul wrote:This is the nearest to original in looks and sound,it has the "mushroom baffle".Not cheap though. http://www.scootopia.co.uk/product/7188 ... ipe--clamp
thanks for the link Paul, i like the look of that and i'm sure the quality is good but it just might be a bit restrictive on my set up, would like to keep the tailpipe as "bigbore" size
Postby peejay » Thu Mar 01, 2018 3:51 pm
ULC Soulagent wrote: scootopia clubby, cheap cheerful and a lot less noisy than bgm, Gori etc etc
like the look of this with the 2 part down pipe, can anyone vouch for it being not too loud?
Postby HxPaul » Thu Mar 01, 2018 4:29 pm
I take it your talking about the Ancillotti type exhaust,if so I've got two,one on a series 2 and one on a series 3.The volume on both is about the same as a KBR clubman.
Postby peejay » Thu Mar 01, 2018 4:40 pm
HxPaul wrote:I take it your talking about the Ancillotti type exhaust,if so I've got two,one on a series 2 and one on a series 3.The volume on both is about the same as a KBR clubman.
thanks Paul
i think that's answered my question, i have a clubmate who has the KBR clubman fitted and that's much nicer on the ear for sure :)
Postby Scooterdude » Thu Mar 01, 2018 4:57 pm
Worth looking at the new v4 BGM clubman should match your kit very well. Don’t be tempted by a Gori though, the one I had was as noisy as hell. You can get clubman end cans now that quietens things downa bit.
Scooterdude
Postby davla » Thu Mar 01, 2018 5:30 pm
Quote from RLC:
'Casa Clubman' 42mm exhaust. standard looks with Clubman improved performance. The quietest Clubman on the market!
https://www.riminilambrettacentre.com/e ... 42-mm.html
davla
Postby peejay » Thu Mar 01, 2018 5:57 pm
Scooterdude wrote:Worth looking at the new v4 BGM clubman should match your kit very well. Don’t be tempted by a Gori though, the one I had was as noisy as hell. You can get clubman end cans now that quietens things downa bit.
i've tried the V1 & V3 absolutely deafening with the RT 225, i'm certainly not going to buy a 3rd one to just be dissappointed again.
Postby davla » Thu Mar 01, 2018 6:18 pm
I have the GP version, without a doubt the best quality standard exhaust that I've found
davla
Postby Watfordwhite » Thu Mar 01, 2018 8:19 pm
Really, any links on the end cans?
Watfordwhite
Postby davla » Thu Mar 01, 2018 11:24 pm
thanks Paul
Isn't the KBA the same as an AF clubman ie.made by the same people but just branded differently?
davla
Postby Scooterdude » Fri Mar 02, 2018 8:49 am
Fair enough mate, but worth trying one of those clubman cans on what you have maybe?
Scooterdude
Postby ToBoldlyGo » Fri Mar 02, 2018 4:22 pm
I run an RT225 with a Sito Ancillotti exhaust and it's definitely got a bit of a crack to it. But other than that it's quieter than a standard clubman exhaust.
ToBoldlyGo
Postby NorthernJordan » Fri Mar 02, 2018 4:36 pm
NorthernJordan
Postby peejay » Fri Mar 02, 2018 5:04 pm
hi guys
thanks for all your imput :)
i've decided to go for the Scootopia 42mm clubman
i'll report back on my findings
PeeJay
Postby Scooterdude » Fri Mar 02, 2018 5:15 pm
NorthernJordan wrote:http://www.mr-partsandstyle.de/epages/63328880.sf/de_DE/?ObjectPath=/Shops/63328880/Products/ESDBGM
End can, can get from SCK too.
I saw a better one than that recently but couldn’t find it when I was looking earlier to reply to the other guy, only a couple of days ago as well.
Scooterdude
Postby LuiLui » Fri Mar 02, 2018 9:57 pm
LuiLui
Postby peejay » Sat Mar 03, 2018 11:23 am
LuiLui wrote:This one maybe? :idea:
https://www.stflambretta.com/shop/exhau ... t/?lang=en
Mark
that muffler looks very neat, might be the answer, who knows
