Scooter dies
Scooter dies
Postby betty2015 » Sun Feb 25, 2018 9:20 pm
Scooter dies suddenly after,20mins at 60ish
Kick start bike and runs like nothing happened
Plenty of fuel from tap
Its not like a heat seize
Thoughts please
betty2015
Re: Scooter dies
Postby Fast n Furious » Mon Feb 26, 2018 1:03 am
What ignition/ stator are you using?
Re: Scooter dies
Postby betty2015 » Mon Feb 26, 2018 7:01 am
Bgm bud its been in a while
betty2015
Re: Scooter dies
Postby MickYork » Mon Feb 26, 2018 8:16 am
What's the rest of the engine spec' ?
Have you measured the petrol flow ?
Is the breather hole clear ?
Re: Scooter dies
Postby Cgt75b » Mon Feb 26, 2018 9:28 am
I had this issue on my scoot a little while ago, would run great and then just cut out. I had the stator rewired and changed the cdi and all is good now.
Good luck with your diagnosis.
Re: Scooter dies
Postby drivera » Mon Feb 26, 2018 1:51 pm
worth checking the breather hole in the filler cap
drivera
Re: Scooter dies
Postby betty2015 » Mon Feb 26, 2018 2:26 pm
plenty of fuel and 1 mm hole in fuel cap
ill change cdi first then stater
what you think
and thanks
betty2015
Re: Scooter dies
Postby missing lynx » Mon Feb 26, 2018 3:33 pm
sounds like the breather hole to me try blowing through it by looking in the tank you allow air back in the tank and clear the air lock
Re: Scooter dies
Postby Rich Oswald » Mon Feb 26, 2018 5:00 pm
missing lynx wrote:sounds like the breather hole to me try blowing through it by looking in the tank you allow air back in the tank and clear the air lock
Don't think it will be breather if it runs for 20m minutes. Sounds electrical to me, CDI or Stator.
Re: Scooter dies
Postby Cgt75b » Mon Feb 26, 2018 6:30 pm
betty2015 wrote:plenty of fuel and 1 mm hole in fuel cap
what you think
and thanks
Yes deffo change the cdi first and see what it's like.
The very best of luck with it.
Re: Scooter dies
Postby CHRIS in MARGATE » Mon Feb 26, 2018 10:38 pm
LT coil on stator.
Re: Scooter dies
Postby Fast n Furious » Tue Feb 27, 2018 1:28 am
This is a common problem that can be an arse to sort. :cry:
Try draining a full tank of fuel into a 2 gallon container just to satisfy yourself its not a fuel flow issue. ( Fuel cap in place of course)
To prove the integrity of the LT coil I suggest you connect a digital multimeter set on 250V AC ( or thereabouts ) to the green wire of the ignition and earth. At tickover it should read around 60volts. At 60MPH it should read around 200volts ( maybe leave the toolbox lid open and tape the meter to the inside of the lid). If the volts drop off when the engine dies then here is your problem. More likely to be this than the CDI.
Re: Scooter dies
Postby HxPaul » Tue Feb 27, 2018 9:10 am
It tells you in Sticky's manual how to do a static test on the stator plate,both LT coil and pick-up.The trouble with this test,especially with the pick-up,is that its not always very reliable because the pick-up can still give a reading even if its brocken because there are two coils and one might be not working.
Re: Scooter dies
Postby Fast n Furious » Tue Feb 27, 2018 11:25 am
The resistance test on the LT coil is just as unreliable also. That's why I recommend an active voltage test whilst the scoot is running.
Re: Scooter dies
Postby HxPaul » Tue Feb 27, 2018 12:15 pm
If it is your LT coil,rather than stripping it down and replacing your stator plate,buy a Readspeed Lukas CDI and run it from your lighting coils,it bypasses your duff LT coil altogether.
Re: Scooter dies
Postby betty2015 » Tue Feb 27, 2018 1:55 pm
thanks ill let you know outcome lads
betty2015
Users browsing this forum: Google [Bot] and 16 guests
