MickYork wrote:but Vespas don't have cones......and in general a smoother ride (but that's probably down to other factors).
Knowledge wrote:My thoughts are that you could fit (eccentric) cones into the frame tube, and then put the bolt into the cones (without the engine) and using a short length of tube, tighten the cones into the frame before welding them with a couple of spot welds.
When the engine is put in the frame, the inner tube of the engine mounts will still tighten-up and be "fixed" to the frame, just as Capt P describes.
Is my proposal much different to the official method?
Martin the lobster rider
Digger wrote:Might have helped if you'd have said that in the first place Martin.
MickYork wrote:Nice thought but how would you get the bolt out after welding ?
When the bolt tightens up, the cones are pulled in and grip on the bolt (to stop it turning).
If you welded the cones in when tightened you wouldn't get the bolt out......
Scooterlam wrote:In the spirit of discussion,
I remember a thread on the old forum where grub screws into the cones was suggested to eleviate rotating cones
fitted after the engine is fitted I guess.
hullygully wrote:but Vespas don't have cones......and in general a smoother ride (but that's probably down to other factors).
but on a Lammy you dont have to hacksaw a rusted engine bolt @ both ends to get an engine out!!& then have to drill the remainder out @ both ends!!!
Users browsing this forum: No registered users and 55 guests
