Kickstart piston problems
Postby Norrie Bodge » Thu Feb 22, 2018 2:46 pm
Lads
a recently fitted new kickstart piston fitted on TS230 using SIL casings!
& on starting the engine in my test frame say 6 - 10 times whilst doin the timing etc...
this happened?
Im not gonna name the reputable dealer i got this from, but an issue i thinks i have is the piston is not IMO goin down deep enough
to get hold of the starter teeth on the 1st gear cog ? 1st gears starter teeth are all good with minimal wear.
has anyone had any issues with a similar problem to this ?
i have seen SIL engines with the endplates ramp chopped off & an SX/LI type fitted onto the side casing.
is this maybe the best way to have a kickstart setup ??
cheers
Norrie Bodge
Re: Kickstart piston problems
Postby HxPaul » Thu Feb 22, 2018 3:18 pm
The slot that the reference pin runs may need elongating.
Postby Norrie Bodge » Thu Feb 22, 2018 3:35 pm
HxPaul wrote:The slot that the reference pin runs may need elongating.
done that m8, had the dremel out & took 1mm off it, still same issue?
cheers
Norrie Bodge
Postby daniel whiteley » Thu Feb 22, 2018 6:07 pm
What shim have you had to fit on the outside of the kickstart shaft to take up the slack before
You fitted the circlip ? You n my slip casings I had the same problem and because I had to use a couple of shims before the circlip went on I just fitted the thickest shim to the inside and that solved my problem
daniel whiteley
Postby HxPaul » Thu Feb 22, 2018 7:48 pm
cheers
If you've done that and its no better,the ramp(if its a SIL engine case)may not be letting the piston (and reference pin) out far enough.The ramp can be ground down or cut it off and fit an Li type ramp by drilling and tapping the cover.
Postby Norrie Bodge » Thu Feb 22, 2018 8:23 pm
daniel whiteley wrote:What shim have you had to fit on the outside of the kickstart shaft to take up the slack before
good call m8 ill give that a try !!
Norrie Bodge
Postby HxPaul » Thu Feb 22, 2018 8:29 pm
Didn't that put your kick start shaft closer to the top plate of the clutch.
Postby Norrie Bodge » Thu Feb 22, 2018 8:31 pm
cheers
did that earlier m8,
im thinking is the SX/LI type option the best to go for anyways??
Norrie Bodge
Postby HxPaul » Thu Feb 22, 2018 8:38 pm
Changing to an Li ramp gives you a lot more adjustment,but seeing that you've ground down the original ramp,I dont think that will solve your existing problem
Postby Norrie Bodge » Thu Feb 22, 2018 8:52 pm
HxPaul wrote:Changing to an Li ramp gives you a lot more adjustment,but seeing that you've ground down the original ramp,I dont think that will solve your existing problem
its better using an old kickstart piston fitted ( new one on its way) but im still not convinced m8, i only took say 0.5mm off the ramp?
it may need more taking off it ???
Norrie Bodge
Postby Norrie Bodge » Thu Feb 22, 2018 8:54 pm
another good call, best left where it is maybe??
its fitted with the thickest shim before circlip i have? say 1.5mm
Norrie Bodge
Postby Storkfoot » Thu Feb 22, 2018 10:39 pm
Would I be correct in assuming your kickstart shaft is SIL?
Postby Norrie Bodge » Fri Feb 23, 2018 12:12 am
Storkfoot wrote:Would I be correct in assuming your kickstart shaft is SIL?
yes
Norrie Bodge
Postby Storkfoot » Fri Feb 23, 2018 9:02 am
In my experience, whilst SIL have produced some really good Lambretta parts in recent years, their kickstart shafts are not in that group. In particular, several years back I found that the slot for the pin is machined in the wrong place. I’d suggest that this may have contributed to extra strain on the pin.
I have GP endplates with Italian kickstart shafts (LI ones from Camlam). As long as you ensure the shaft clears the clutch top plate, I have never had a problem again.
If you compare the quality of a SIL shaft to the Italian one, they are streets apart.
If I was you, I would change the kickstart shaft and work from there. You may well have issues now because of what you have done to the ramp though.
Postby rossclark » Fri Feb 23, 2018 1:10 pm
There's SIL and SIL I find - I had two in very similar packaging. One from eBay (as part of a job lot of other parts) and one from Restos. The Restos one seems fine but the other one is dreadful - fits nowhere. Splines are wrong, machining is rough as and the spring retaining hole half the depth it needs to be - binned.
I can only presume the ebay one was forgery in SIL packaging.
I also usually remove the GP ramp and fit the Li style one on the casing for two reasons -
More adjustable
Less strain on endplate
Postby daniel whiteley » Fri Feb 23, 2018 4:01 pm
Didn't that put your kick start shaft closer to the top plate of the clutch.[/quote]
I only fitted half thickness of the 2 mm shim I had on (so 1mm either side) and it didn’t catch the clutch , worth a try just experimenting with it to help
daniel whiteley
Postby Norrie Bodge » Fri Feb 23, 2018 6:38 pm
Thanks for the replies
I Ended up fitting the new piston to a different SIL kickstart shaft I had
& feels loads better, also fitted 2 shims before the circlip = 2.2mm
Here’s the old kickstart shaft that was fitted!!
Norrie Bodge
