MK Monty wrote:This was covered a few months ago. With the screw out, and headset top off, you will see a small round aluminium disk that you can tap out with a small screwdriver. It’s just a dust cap and can be reused if you are carfull. Under the cap you should see the tail end of the lock that should simply push out the front. The tail of the lock is a cam that as it turns with the key pushes a small springloaded piston down to locate in the chrome ring if you have one. Many are broken as they won’t deter the low life of today. If you have the key you can normally just pull the lock out. But a screwdriver from the back will dislodge it.
MK Monty wrote:You don’t say if when you turn the key can you see the cam flip over on the inside. The lock may well be turning but the piston is sticking down so you can not turn the bars. Get some lube down there. If you look at the casting inside the headset just in front of the round disc you should have a set screw of some type remove this as it locks the barrel of the lock into the headset. If that’s out then it’s only paint or corrosion holding it in.
mainstand wrote:Well I can't see any screw. As I said, this is a Spanish S2.
Users browsing this forum: Baidu [Spider] and 63 guests
