Smiths Rev Counter Conversion Pics
Postby davla » Wed Jan 31, 2018 4:41 pm
Thought I'd post some pics of my Smiths rev counter conversion. The gearbox came from Gaggs and the side casing was modified by Rimini, I also had to extend the brackets on the exhaust to clear the gearbox. I still need to route cable through crossmember and mount clock but it works a treat. I chose to keep the side casing finish original in keeping with the rest of the scooter and not have it polished or acid dipped.
davla
Re: Smiths Rev Counter Conversion Pics
Postby Adam_Winstone » Wed Jan 31, 2018 7:34 pm
Very nice
Postby Raveydavey » Wed Jan 31, 2018 11:27 pm
Superb!
Raveydavey
Postby Norrie Bodge » Thu Feb 01, 2018 10:23 am
Smart as fook m8 ;-)
Norrie Bodge
Postby Dimitrios_231 » Thu Feb 01, 2018 10:24 am
Excellent work
Dimitrios_231
Postby tim_mason » Thu Feb 01, 2018 10:44 am
Nice looking job , I would check the angle drive as the one you have fitted is the plain bearing type which are the 4000 max rev ones , i only use the ball bearing type which are the 7000 rev drive,
tim_mason
Postby davla » Thu Feb 01, 2018 10:54 am
tim_mason wrote:Nice looking job , I would check the angle drive as the one you have fitted is the plain bearing type which are the 4000 max rev ones , i only use the ball bearing type which are the 7000 rev drive,
Are the gearbox casings both the same size/shape?
davla
Postby tim_mason » Thu Feb 01, 2018 10:59 am
yes
tim_mason
Postby davla » Thu Feb 01, 2018 11:02 am
tim_mason wrote:yes
That's ok then, if there's an issue I'll send it back to Gaggs. How can you tell the difference, is it from the number on the end?
davla
Postby tim_mason » Thu Feb 01, 2018 11:35 am
yes, I cannot quite see the full markings which indicate the ratio, just to check if that is correct as well ,
tim_mason
Postby Dimitrios_231 » Thu Feb 01, 2018 3:38 pm
Some info that I found ;)
RGB1507-1508 series
A range of gearboxes primarily for driving high reving engine, rev counters (tachometers) and designed to run at speeds of up to 7000PRM when fitted with ball race bearings, and up to 4000 RPM with self lubricating bronze bearings. Various ratios are available as well as reversing and non reversing.
RGB1507 (Ball Race) Maximum Input Revs 7000
RGB1507- 00 2:1 Ratio Non Reversing
RGB1507- 01 2:1 Ratio Non Reversing Long Spindle (.890”)
RGB1507- 02 2:1 Ratio Reversing
RGB1507- 03 4:1 Ratio Reversing
RGB1507- 04 2:1 Ratio Reversing (output .120” Internal Square)
RGB1507- 05 Not Allocated
RGB1507- 06 8:1 Ratio Reversing
RGB1507- 07 8:1 Ratio Non Reversing
RGB1507- 08 1:1 Ratio Reversing
RGB1507- 09 1:1 Ratio Non Reversing
RGB1507- 10 1:1 Ratio Non Reversing Long Spindle
RGB1507- 11 2:1 Ratio Reversing Long Spindle
RGB1508 Maximum Input Revs 4000
RGB1508- 00 1:1 Ratio Painted Black
RGB1508- 01 2:1 Ratio Reversing
RGB1508- 02 1:1 Ratio Reversing
RGB1508- 03 4:1 Ratio Reversing
RGB1508- 04 1:1 Ratio Reversing Painted Grey
RGB1508- 05 1:1 Ratio Reversing
RGB1508- 06 2:1 Ratio Reversing Painted Grey
RGB1508- 07 2:1 Ratio Non Reversing
RGB1508- 08 1.5:1 Ratio Reversing
RGB1508- 09 4:1 Ratio Non Reversing
RGB1508- 10 3:1 Ratio Non Reversing
Dimitrios_231
Postby davla » Thu Feb 01, 2018 9:06 pm
Great, thx
davla
Postby davla » Mon Feb 05, 2018 3:55 pm
I checked with Gaggs and they said they only sell the ball bearing type and to ignore the part number on it as some of the old boys in the workshop still use the old numbers, so all good :D
davla
Users browsing this forum: Dom and 74 guests
