Mugello piston rings recommendations??
Postby mm man » Tue Jan 30, 2018 9:11 pm
Hi I have a 185cc Mugello CL3 ( one of the early versions) kits that I have been running for a few years now .
I will be looking at changing the rings soon as I am still running on the standard set I got with the kit years ago.
I have heard that the original rings wear quite quickly and that there are some better quality ones out there that last a lot longer but I can’t remember what make and who supplies them ?
Can anyone please recommend ones they have used ....what should I be looking for and from where ?
All help appreciated
mm man
Re: Mugello piston rings recommendations??
Postby Stevepshipley » Tue Jan 30, 2018 9:49 pm
hi
I replaced mine off a circa 2005 kit with rings from Mike Phoenix. don't know any more than that.
Cheers Steve
Stevepshipley
Postby mm man » Tue Jan 30, 2018 10:11 pm
Thanks for the reply Steve but it looks like Mike Phoenix is currently out of stock of 186 ?
mm man
Postby martin1310 » Wed Jan 31, 2018 7:25 am
robbo speed stocks all mugello parts many thanks martin
martin1310
Postby ULC Soulagent » Wed Jan 31, 2018 5:39 pm
Riken rings are a good substitute ;)
ULC Soulagent
Postby Fast n Furious » Wed Jan 31, 2018 5:49 pm
All Nicasil cylinders give the first set of rings a hard time irrespective of who makes them, so I wouldn't worry too much about it. You will see a substantial improvement on wear with the 2nd set from the same manufacturer.
Postby mm man » Wed Jan 31, 2018 10:22 pm
martin1310 wrote:robbo speed stocks all mugello parts many thanks martin
Had a quick look online is he only on Facebook?
I don’t have FB :|
mm man
Postby Cgt75b » Thu Feb 01, 2018 7:53 am
Cambridge lambretta could be a good place to look.
Good luck.
Postby HxPaul » Thu Feb 01, 2018 9:41 am
Postby mm man » Thu Feb 01, 2018 8:25 pm
Cheers guys
Checking the above options
I sent MB a message ref these rings to check the suitability and got a message back saying ... “they are the same as Wiseco and pretty sure they are not suitable “ ?? Any ideas ?
Any one used the Grand-sport version ? They seem to be the ones I remember people talking about a few years ago ?
mm man
Postby HxPaul » Thu Feb 01, 2018 11:30 pm
It says on the mb site (that link) that they fit
MB Race-tour pistons
Wiseco pistons
Wossner pistons
MUGELLO pistons
Imola pistons
and Casa pistons
They're 64 mm x1 mm wire piston rings,I have bought and fitted some to a Casa 185 kit.
Postby mm man » Fri Feb 02, 2018 12:25 am
HxPaul wrote:It says on the mb site (that link) that they fit
Wiseco pistons
Wossner pistons
MUGELLO pistons
Imola pistons
and Casa pistons
Yep I saw the link and the list and I just asked them what make were the rings ? As it only states race/tour and if they were a standard type ring ? or one of the “longer life coated/ material ” type rings ?
And that was the answer they gave me ??...seemed a bit odd to me .
mm man
Postby HxPaul » Fri Feb 02, 2018 11:01 am
Postby lambypolo » Fri Feb 02, 2018 10:54 pm
Wiseco pistons
Wossner pistons
MUGELLO pistons
Imola pistons
and Casa pistons
Sorry, that was my fault. We have 3000 products and it's hard to keep on top of everything.
lambypolo
