Series 1 shocker length
Postby rumiman » Mon Jan 15, 2018 10:41 pm
Just building a series 1 with reed valved avanti, only a that's cock of clearance frame to reed block at 31.5mm "&series 1 shocker length" , has anyone runa series 1 with a shorter length shocker or will you do clearance be an issue ? Mb clubman exhaust .
rumiman
Re: Series 1 shocker length
Postby rumiman » Mon Jan 15, 2018 10:42 pm
Gnats cock of clearance not that's cock.
rumiman
Postby rumiman » Mon Jan 15, 2018 10:44 pm
Bloody predictive thingy !!! Was asking if "ground clearance" was likely to be an issue.
rumiman
Postby HxPaul » Tue Jan 16, 2018 9:52 am
I had the same problem with the rear shocker on my series 2,in the end I used a series 3 shocker (305mm).I've run the scooter for a year without a problem.So if anybody wants a Scootopia adjustable rear shock for a series 1 or 2,I've got one cheap,never been used.
Postby Tractorman » Tue Jan 16, 2018 9:53 am
Could try offset engine mounting cones.
Postby Watfordwhite » Tue Jan 16, 2018 12:19 pm
Yes, my S2 runs a 225 Rapido & reed motor. I used a S3 rear shock and offset cones. No problems.
Watfordwhite
Postby rumiman » Tue Jan 16, 2018 1:40 pm
Thanks for the replies, appreciated.
rumiman
Users browsing this forum: Google [Bot] and 45 guests
