bike grim wrote:Yep I also spoke to them and had a good look at the kit. They reckon you could pull some pretty high gearing on them as well which further gets my attention. Did you hear the engine running ? That pipe - It’s a bit loud - motocrosser loud. I could live with it though
Raveydavey wrote:I talked to the Chisel speed guys yesterday at the Newark bike jumble thingy. They were adamant there is no issue fitting these to Italian blocks. As Corrado says the transfers have had a corner seemingly blocked, and the Chiselspeed guys said if you open it up there, then it will need some welding. Otherwise its not a problem.
I'm pretty much sold on it. Waiting to see the new report on SLUK this week, before pressing the button.
bike grim wrote:Suppose it’s no big thing getting them welded.I reckon Chiselspeed can get this done as well.
bike grim wrote:If it’s like the smallframe Quattrini top ends they always have a little “step”
in the base of the transfers that you can remove (Dremel) if you want to open them up a bit. I agree though it’s probably not worth it. I wouldn’t mind the chance of offering up my TV175 casing to that barrel Martin if you’re open to that? Just to check and see if it would work without welding
Users browsing this forum: No registered users and 49 guests
