a-teamlambretta wrote:No issues as a long rod would be used
HxPaul wrote:a-teamlambretta wrote:No issues as a long rod would be used
What difference would using a long rod make ?
Theres a video of the kit and also an article on sluk which you can get on this thread - viewtopic.php?f=7&t=9118
missing lynx wrote:A far as I read it they use a std length rod but it does require a case with plenty of gasket face
Reading through what Martin of Chiselspeed says in Scootering, he appears to have anticipated problems with the gasket face.
In the event, the "standard Italian Li125 case" they used presented no problems.....
Raveydavey wrote:This is the most confusing part; I've read somewhere Italian cases are the least likely to fit. Indian and Spanish ones supposed to be fine. It would be great if someone published gasket face sizes so we can check prior to buying.
Users browsing this forum: Google [Bot] and 38 guests
