special brew wrote:Running a rb 20 , like a div I've only been running at 3% , big end totally gone , when inspecting crank it as got realy hot around big end , would running at 3% cause that
special brew wrote:No damage to cylinder or piston , it's a mec crank bought from Glasgow lambretta , done under 1000 miles , running on exol premium semi synthetic
Solid Air wrote:special brew wrote:No damage to cylinder or piston , it's a mec crank bought from Glasgow lambretta , done under 1000 miles , running on exol premium semi synthetic
I paired a brand new 60mm Mazzuchelli with a GT186 and was using fully synth Exol at 3%. The engine had a similar big end failure after about 3.5k miles last year. It was a brand new build and I'd like to think well built and set-up, the only thing we could attribute the failure to was lack of 2t lubrication(?).
burnside wrote:Solid Air wrote:special brew wrote:No damage to cylinder or piston , it's a mec crank bought from Glasgow lambretta , done under 1000 miles , running on exol premium semi synthetic
I'm only running 3% Rock Oil Groundsman semi-synth in both my GT186 with GT 60/110 crank and GT200 with 58/107 MEC Crank, done over 5k miles on both without any issue and ride them both hard.
I also use the 'that's about right' method of adding 2T, so sometimes could be running at 2.5% other times 3.5%
Wasn't there a dodgy batch of MEC cranks a couple years back, where a lot of people were having issues, surely that couldn't have just been down to lack of 2T?
Warkton Tornado No.1 wrote:Personally, I think that Rayspeed have really tried to avoid anybody having issues with their product, especially in this instance. This link is what 'they' have to say about the speculation about suitable big ends & lubrication:
http://www.afrayspeed.co.uk/index.php?page=Per_rb20
dscscotty wrote:The MEC crank, unless fitted with an RB type 18 Roller which is in fact an RG500 Bearing will not be up to the job, also if memory is right, I'm sure the last MEC-116 Crank I worked on had a 22.9mm pin, making it not suitable for upgrade to RB/Jap type upgrade. You'll need some webs that use a 22mm pin.
This is almost certainly why the crank has failed as it was not up to the spec required for a high revving Rb.
