HELP plse fitting S3 stainless legshield trim
Postby Dobo » Sun Aug 31, 2014 11:21 am
Hi guys, without too much fore thought I purchased some legshield trims. On receipt I realised that fitting was not going to be that straightforward!? I removed the legshield rubber edge beading and offered up the stainless trim . . . no that isn't going to be easy! There has to be a trick or two to aid fitting, so those who have done it PLEASE, please your advise will be much appreciated. Thanks in anticipation. Ian.
Dobo
Re: HELP plse fitting S3 stainless legshield trim
Postby Jazzy b » Sun Aug 31, 2014 11:28 am
I put some double leg shield trim on my s2 Paul at scooter restorations gave me a old pair of leggys to fit and get the shape you can put cling film round the leggys fit the top get a mate to help you he holds top while u slowly push it on all the wAy down then pull bling film out or you can cover on grease hope this helps but it is a b..stard of a job
Jazzy b
Postby phil23fair » Mon Sep 01, 2014 9:33 am
I thought you had to cut the lip off your legshields to make stainless trim fit
phil23fair
Postby Jazzy b » Mon Sep 01, 2014 3:45 pm
I've heard that but dident need to with mine 8-)
Jazzy b
Postby Rich Oswald » Mon Sep 01, 2014 5:20 pm
No don't cut the lip off as you will never be able to go back to rubber trim. I used cling film and lots of grease on my S1, horrible job but have patience and you will get there. One side went on easily for me but the other side was a right pig,
Postby Dobo » Tue Sep 02, 2014 9:31 am
OK thanks for the info so far guys. There seems to be some consistency with 'clingfilm' and grease . . . but what's this 'leggys' mentioned by you Jaz? Is that some old rubber edging or what? All HELP appreciated. Ian.
Dobo
Postby shep65 » Tue Sep 02, 2014 11:17 am
'legshields'.
shep65
Postby Jazzy b » Tue Sep 02, 2014 4:31 pm
Sorry m8 leggys are legshields the old pair allowed me to get them in to shape as mine were painted 8-)
Jazzy b
Postby Donnie » Tue Sep 02, 2014 5:14 pm
phil23fair wrote:I thought you had to cut the lip off your legshields to make stainless trim fit
you will if you bought vietnamese stainless trim for sure, and then your legshields are ruined.
Donnie
Users browsing this forum: Google [Bot] and 87 guests
