gizmo wrote:Any tips on getting the lip straight on the frame for the legshields to sit on. On with dry build and side panels are all over the place
coaster wrote:Now you've sorted the thread titlea few more details would be helpful. Is the frame hoop lip damaged? or is just that the panels don't fit up properly?
The later could be due to the frame having been stood upright on the rear of the hoop for transportation purposed (more on a container) The panels themselves can also suffer distortion if they have had panel beating or have been blasted. If you are doing a dry fit, don't forget to fit the rubber buffers on the thear frame legs as these push the panels out which has the effect of pulling the front and rear of the panel in slightly.
Users browsing this forum: No registered users and 48 guests
