Scooterdude wrote:Just been tasked with fitting a Mugello 186 kit for a mate, a direct replacement bolt on kit the bumf says, comes with .2, .3 and .7 base gaskets so I find I need the .2 to get the required squish, put the gasket on the case one side of the gasket is hanging off one transfer completely and the other side is just holding by maybe about 1mm. Found a standard Lambretta base gasket fits well but is to thick at .75 so ring cam lam in the hope they can offer me an alternative gasket, 1st very unhelpful bloke on the phone eventually puts me through to a second and even more unhelpful bloke in the workshop, I explained what the problem was and he tells me I have the right gaskets included in the kit....so I explained again what was wrong and got much the same reply.
So my question is does anybody do a .2 base gasket that fits (and actually covers the transfers) of a Mugello 186 (latest version) that's going on an Italian LI case?
HxPaul wrote:Scooterdude wrote:Just been tasked with fitting a Mugello 186 kit for a mate, a direct replacement bolt on kit the bumf says, comes with .2, .3 and .7 base gaskets so I find I need the .2 to get the required squish, put the gasket on the case one side of the gasket is hanging off one transfer completely and the other side is just holding by maybe about 1mm. Found a standard Lambretta base gasket fits well but is to thick at .75 so ring cam lam in the hope they can offer me an alternative gasket, 1st very unhelpful bloke on the phone eventually puts me through to a second and even more unhelpful bloke in the workshop, I explained what the problem was and he tells me I have the right gaskets included in the kit....so I explained again what was wrong and got much the same reply.
Try Chiggy Chambers (lambretta upgrades)He does .25mm thick gaskets,these are the thinnest ones I can find.
http://www.lambrettaupgrades.co.uk/apps ... ow/5192842
No. after my mate spending almost £500 with them then me being snubbed on the phone I certainly won't be going back there any time soon thank you very much.Phil D wrote:Scooterdude wrote:Just been tasked with fitting a Mugello 186 kit for a mate, a direct replacement bolt on kit the bumf says, comes with .2, .3 and .7 base gaskets so I find I need the .2 to get the required squish, put the gasket on the case one side of the gasket is hanging off one transfer completely and the other side is just holding by maybe about 1mm. Found a standard Lambretta base gasket fits well but is to thick at .75 so ring cam lam in the hope they can offer me an alternative gasket, 1st very unhelpful bloke on the phone eventually puts me through to a second and even more unhelpful bloke in the workshop, I explained what the problem was and he tells me I have the right gaskets included in the kit....so I explained again what was wrong and got much the same reply.
Ring back and enquire about a Targa Twin they'll be all over you.
No. after my mate spending almost £500 with them then me being snubbed on the phone I certainly won't be going back there any time soon thank you very much.[/quoteScooterdude wrote:Phil D wrote:Scooterdude wrote:Just been tasked with fitting a Mugello 186 kit for a mate, a direct replacement bolt on kit the bumf says, comes with .2, .3 and .7 base gaskets so I find I need the .2 to get the required squish, put the gasket on the case one side of the gasket is hanging off one transfer completely and the other side is just holding by maybe about 1mm. Found a standard Lambretta base gasket fits well but is to thick at .75 so ring cam lam in the hope they can offer me an alternative gasket, 1st very unhelpful bloke on the phone eventually puts me through to a second and even more unhelpful bloke in the workshop, I explained what the problem was and he tells me I have the right gaskets included in the kit....so I explained again what was wrong and got much the same reply.
vintage65scoot wrote:Hi plus 1 ive used lambretta upgrades 0.25 base gaskets on my Mugello kits very well fitting maybe use with a little three bond as they are very thin I did and haven't had a problem good luck
Would you care to elaborate?dscscotty wrote:I'd be more inclined to focus on port timings than squish with mugello cylinders, they can be a little inconsistent to say the least!
Rich Oswald wrote:Beware all, of criticising dealers on here. It is against forum rules.
Cheers guys,
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 45 guests
