Recommended engine oil
Postby andrewgc » Mon Nov 13, 2017 9:27 pm
Guys,
just asking what engine oil you recommend for a bog standard series 1 LI (albeit fitted with a 125 special engine) , theres such a vast range out there i want the best one available as the cost difference between most of them is not enough to worry about
thanks all
andrewgc
Re: Recommended engine oil
Postby ToBoldlyGo » Mon Nov 13, 2017 9:55 pm
They will all do the trick. Just so long as you get the right grade.
ToBoldlyGo
Postby gaz_powell » Mon Nov 13, 2017 10:01 pm
ST90 any brand - I use lubetech and buy in 5L bottles
Postby HxPaul » Tue Nov 14, 2017 10:46 am
gaz_powell wrote:ST90 any brand
+1
Postby CHRIS in MARGATE » Tue Nov 14, 2017 11:20 am
Take it you are asking about Gearbox oil and not the 2 stroke oil that lubricates the crankshaft and top end ?
Postby Knowledge » Tue Nov 14, 2017 3:45 pm
Good point Chris ^
Postby Phil D » Tue Nov 14, 2017 4:04 pm
If it's 2t your after I found Motul 510 synthetic to be really good pricey at £7Ltr.
Virtualy no smoke which I like.
That was before I bought up all the Castrol fully synthetic 2t localy Tesco were selling it off a £2.50Ltr.
Again low smoke.
Gearbox-
Rock oil ST 90 for me easily obtainable £5/6 per Ltr.
Everybody seems to have there own preference with oils and fuels :)
Phil D
Postby Fast n Furious » Tue Nov 14, 2017 6:33 pm
Don't be tempted to use EP oils in the gearbox. EP is good for the gears but bad for the clutch. Only use EP oils in bikes with dry clutches.
Postby andrewgc » Tue Nov 14, 2017 7:25 pm
yes guys , i should have explained better it was gearbox oil i was asking about but thanks for the 2 stroke advice also
andrewgc
Postby andrewgc » Tue Nov 14, 2017 7:28 pm
Phil D wrote:If it's 2t your after I found Motul 510 synthetic to be really good pricey at £7Ltr.
Again low smoke.
Gearbox-
Hi Phil , can you give the code for the castrol oil please
andrewgc
Postby Phil D » Tue Nov 14, 2017 7:39 pm
Again low smoke.
Gearbox-
The Castrol offer was a few months ago so you may be still lucky .
If you see it on the shelf ask them to check the price as it was marked up at £7 ltr but when scanned it came up reduced to £2.50 .
Dont think they'll be any left in West Yorkshire as I bought most of it :o
Phil D
Postby andrewgc » Tue Nov 14, 2017 8:30 pm
Thanks mate i will try my local tescos
andrewgc
Postby Phil D » Tue Nov 14, 2017 10:23 pm
Also try Tesco filling stations as they tried to hide some in there too. :lol:
Phil D
Postby andrewgc » Tue Nov 14, 2017 10:32 pm
cheers :)
andrewgc
Postby burnside » Wed Nov 15, 2017 10:21 am
I use Rock Oil ST90 with standard clutch, Putoline SAE90 with Readspeed 5 plate clutch (as per their recommendation) and Castrol Classic ST90 with a standard clutch in my sidecar combo (again on recommendation).
2T oil, I use Rockoil Groundsman Semi-Synth, works out at around £4 a litre from Tines, you really do not need modern fancy fully synth in a standard barrell
burnside
Postby Phil D » Thu Nov 16, 2017 4:28 am
Totally agree but the O/P said he isn't worried about the cost and if you can find fully synthetic for £2.50 Ltr and spank Tesco at the same time why not. :D
Phil D
Postby burnside » Thu Nov 16, 2017 8:00 pm
Phil D wrote:you really do not need modern fancy fully synth in a standard barrell
Good point well made :lol:
burnside
Postby andrewgc » Sat Nov 18, 2017 10:11 pm
Cheers for the great advice guys I'm sorted now
andrewgc
Postby maddogmadox » Mon Nov 27, 2017 9:19 pm
Phil D wrote:Also try Tesco filling stations as they tried to hide some in there too. :lol:
Hi Phil D you stated that this was fully synth castrol oil in your earlier post . this oil is actually semi synth not fully synth if you are not aware
it is the power one racing that was the fully synth version , tescos never sold power one racing .
i also bought a large stock of the oil while the deal was on at tesco a while ago , although i dont use it myself
maddogmadox
Postby Phil D » Mon Nov 27, 2017 10:08 pm
:D I'm sure it said fully synthetic in German , :lol: whatever it is it was a bargain.
Just shows what Mark up Tesco put on stuff.
Apologies if anyone has been misled. :oops:
Phil D
Users browsing this forum: No registered users and 49 guests
