VHSA 30 mm Delorto - TS1 set up
Postby Strummer10 » Sat Jul 08, 2017 10:14 am
Hi All, apologies I have asked before elsewhere and lost some data on the subject, but having now just built my TS1 225 engine and got it riding in need to fine tweak a few things. Can I ask your valid opinions on the following:-
Points to note I have a version 3 - BGM Clubman and 30mm Delorto VHSH flatslide, not currently filtered and my preference would be to filter it.
1/ On gearing - Should I stick with the GP 200 Italian - 19/46 gearing OR go with an Li 150 gearbox and if so what front and rear sprocket for an all rounder.
2/ Ideal jetting set up for the BGM clubman, if anyone has same ?
3/ Just to be clear which screw does the mixture, is it the smaller one or the one with the spring on ? and is it inwards to richen ?
Strummer10
Re: VHSA 30 mm Delorto - TS1 set up
Postby Strummer10 » Fri Jul 14, 2017 3:01 pm
OK action as follows
Point 1 - gonna stay with GP Italian 200 box, better for my needs.
Point 2 - No idea, but gonna probably go to an expansion as i'm pretty sure its holding back.
Point 3 - its the smaller screw lol......
Strummer10
Postby Dazts1 » Tue Aug 08, 2017 9:35 pm
Did anybody have the settings for a ts on this carb as I'm about to try one ?
Thanks daz
Postby Toddy » Wed Aug 09, 2017 7:09 am
Here you go Daz
Carb Set Up (GP TS1 225) PT Dynod @ Chiselspeed 2014
Dellorto 30 mm Flatslide VHSH/ADS3
Slide 40
Needle (Washer fitted bet 3/4 position) K21 P3
Atomiser DQ269
Main Jet 155
Pilot 36 over CDI Tube
Choke 60 Pilot
Float Valve 300
LI150 GBOX 17x46 81 link 4.6
Ram air MR-012 filter
Postby Dazts1 » Mon Aug 14, 2017 10:33 pm
Thanks for that Toddy
Just checked my reeds all good. Next step is to fit this carb. Mine is a 30 vhsa. I don't think there's much difference between the 2 carbs. I've ordered up the relative jets should have it fit this week.
Postby Adam_Winstone » Mon Aug 28, 2017 10:51 am
Toddy,
Are you running the generic CD1 emulsion tube under the pilot jet or do you have a sized emulsion tube fitted to restrict the pilot circuit?
Ta
Adam
Postby Toddy » Mon Aug 28, 2017 11:27 am
Adam_Winstone wrote:Toddy,
Ta
Adam
Generic I believe
Postby Adam_Winstone » Sat Sep 02, 2017 4:14 pm
^... I ask as you're running a pretty big pilot, which makes me wonder whether this is then being restricted with a sized emulsifier tube (quite a common practice by some UK tuners... but not others). Depending on emulsifier tube this may make a very considerable difference to the pilot size that you need.
Ta
Adam
Postby Simon ELC » Sun Sep 24, 2017 12:14 am
Here's mine
TS1 253 Touring/Fast Road in between.
Fran Race
Li 150 17x48 (4.8)
42 pilot over CD1 emulsion tube. The emulsion tube ain't moving unless I drill it out.
K24 needle 2nd clip
DQ 266 Atomiser
120 Main with adjustable power jet.
Augusto 700
Low compression Ron Moss head 9.2:1 geometric
Simon ELC
Postby Strummer10 » Fri Nov 03, 2017 9:10 am
Anyone running the 30 mm VHSH with a BGM Clubman ?
Strummer10
Return to Carburettors
Users browsing this forum: Bing [Bot] and 47 guests
