foremanbob wrote:Try setting it up with a BGM flywheel with no window... proper PITA that is to get it right...
Well done for finally realising that static timing is never really enough....
davla wrote:foremanbob wrote:Try setting it up with a BGM flywheel with no window... proper PITA that is to get it right...
TBH the holes in the flywheel were no help, I still whipped the flywheel off about half a dozen times to get it right.
MickYork wrote:davla wrote:foremanbob wrote:Try setting it up with a BGM flywheel with no window... proper PITA that is to get it right...
That's where the external pick-ups from Antony Tambs are a godsend......
Phil D wrote:I don't pretend to know much about Lambretta electrics but the external pick up is a brilliant idea.
Ok you have to spend a bit of time fitting it but if that's the only negative count me in - I bought one.
In fact all Mr Tambs products look fantastic properly tested products made by someone who actually knows his stuff.
Phil D wrote:£30 inc p+p
davla wrote:Phil D wrote:£30 inc p+p
Well you can't really grumble at that can you? Has he got a website?
Phil D wrote:davla wrote:Phil D wrote:£30 inc p+p
I'll pm you -not sure it may be breaking forum rules- regards advertising.
Users browsing this forum: No registered users and 118 guests
