Stripped thread- what are my options?
Postby al pushpak » Sat Oct 28, 2017 9:17 pm
Hi, just after a bit of advice, had the mag flange off my engine this afternoon to fit a new mag gasket & repack the bearing with grease & when it came to tighten everything down one of the mag/crankcase nuts wouldn't tighten & just kept spinning, tried a new nut but still no joy, fitted a slightly longer stud which bit slightly but still not enough to hold it tight :roll: just wondered what my options are? can it be taken out to m7 ? or does it need an insert? thanks for any info ;)
al pushpak
Re: Stripped thread- what are my options?
Postby steve t » Sat Oct 28, 2017 10:51 pm
M6 helicoil kit cheap enuff from ebay
steve t
Postby Fast n Furious » Sun Oct 29, 2017 1:01 am
+1
Postby Tractorman » Sun Oct 29, 2017 8:41 am
Never been a great fan of helicoils for no other reason than ones others people have put have come out when I been working on their scooters. Perhaps they were not fitted properly. Anyone had any experience with inserts?
Postby coaster » Sun Oct 29, 2017 9:08 am
steve t wrote:M6 helicoil kit cheap enuff from ebay
I did exactly that on a recent build as one of the stator threads stripped. I bought an M6 kit off ebay which came with the drill, tap, insertion tool and insets. Very easy job, took no time at all. It it comes out with the bolt nest time I'll just fit a new insert. 8-)
Postby al pushpak » Sun Oct 29, 2017 9:43 am
Thanks for all your replies, the kits do seem cheap enough to buy, think I will give it a go, if I'm not successful then I will let an adult have a go :) thanks ;)
al pushpak
Postby dickie » Sun Oct 29, 2017 3:11 pm
al pushpak wrote:Thanks for all your replies, the kits do seem cheap enough to buy, think I will give it a go, if I'm not successful then I will let an adult have a go :) thanks ;)
Honest, it's dead easy. Just make sure you put the coil the right way round. Hard to explain in words but there's sure to be a YouTube video.
Postby Phil D » Sun Oct 29, 2017 3:57 pm
It's worth pointing out the kits usually come with the shortest depth insets,longer ones are easily obtainable .
The company I used was called Essex Fasteners I think.
Cheap as chips and very handy.
Phil D
Users browsing this forum: No registered users and 56 guests
